18lbs? Is that due to the way slicks are designed, or do you run DOT tires that low too? I was pleased and certainly getting some heat in the tire at 29psi front and rear, but I plan on going down in the front for next time.
BJS, what pressure were you running? Have you tried them again at a different pressure?
