61 - 66 of 66 Posts
Can someone check my work and make sure I did it correctly?
I am installing an Aracer mini 5 and a chimera intake tomorrow so I will tune for best fuel air mixture, eliminating the worry of the throttle body line to the canister cited above. Hence, I just capped it, item #2 in the picture.
#1 is the solenoid connector, vinyl tape to cover it and zip tied it out of the way.
#3 is the connection of the tank vent line using a run of plastic tubing.
Am I good to go? Bike starts up and runs fine with no check engine light.
i used one of these to completely replace #3 in your picture
As did I.
Two quick questions. Yes, I know I can make my own solutions, but I'm curious.
1. What's the type of the solenoid connector and/or does anybody know where I can get a cap that snaps onto the connector?
2. Where did you get the cap or plug for the manifold?
By the way the parts I removed total 1.05 pounds on my HF scale.
Reactions: 50-50
any guides / video on how to do this for a 2022+ model ?
i looked up and see it for other generations, i think the placement is different for 2022+ models.
61 - 66 of 66 Posts
