Going on a trip, what tools to carry?
5.4K views 18 replies 11 participants last post by  TheBallew
#1 ·
On the morning of April 1st, my GF and I are going to ride the bikes to dahlonega, GA. We're going to spend the weekend exploring all the awesome curvy roads in the area.
So, what tools would you recommend I take to solve the most likely issues the Grom is likely to have? I'm thinking the most likely things to go wrong are a flat tire, blown fuse, and I'm not sure what else. Maybe a wire connection coming lose somewhere.
Seems like if I had a 5 & 6mm hex; 8, 10, and 12mm sockets; Phillips screwdriver; two paper clips; spare fuses; tire plug kit; and some way to inflate a tire I could resolve most issues that are likely to occur.
Anything else you can think of? My insurance has coverage for roadside assistance, so if something really awful happens I can get help (eventually).
#5 · (Edited)
On our trip last year (2000 miles)
Only took puncture repair kit and leatherman.
Think there is a few zip-ties and a roll of tape under the seat, didn't look.
Didn't see the need for loads of tools.
Not sure if you have them over there, but don't take the foam tyre repairer.
They are crap, tried 2 cans to repair small puncture.
Luckily my wife had the rope type, so soon on the road again.
Good luck on your trip
This stuff didn't work .
This is what I now got
Dog
#7 ·
Dog
That looks like a pretty well set up kit right there. :):)
#8 ·
StrayDog's tire repair kit is a good one. the only thing i would add to that kit would be a parasitic/female-female hose so you can also drain other tires to fill yours (2 tires at 1/2 rated psi is better than 1 at full and 1 and 0).
i would bring along one a vise grip as well as an adjustable/crescent wrench. While they arent perfect for roadside repairs, its better than nothing.
#12 ·
tire repair kit comes with a compressor.
That compressor is a good idea, those little Co2 cartridges don't have much air in them.
This is what I just bought for this year's trip.
Nice compact unit, only about 4" square
Seems to work great, if a bit slow (Small pump)
Dog
#11 ·
To add to what you already listed and was suggested depending on carrying space:
14mm box wrench
19mm socket in 3/8" drive
Spark plug socket in 3/8" drive
3/8" drive socket wrench
3/8" drive torque wrench
That's stuff I make space for on my longer rides.
#13 · (Edited)
I got this from HFT as a backup pump, cheap Chinese air pump but it works, also got a free meter when I bought my pump using a Free meter coupon
$9.99 better than pumping by hand, just make sure you test it before going on your trip and make a special wire plug so you can use your batter as power
12V Air Compressor - 250 PSI, Compact Air Compressor
I also carry one of these on really long trips never know when your battery decides to choke on you
Micro-Start XP-1 Pocket Size Jump Starter by Antigravity
and a spare head light bulb.
yep using FREE coupon at HFT gets you going on a road trip
FREE Flashlight, Batteries, and Multimeter at Harbor Freight « I Crave Freebies
Last but not lease a AAA membership card or any auto insurance road side assistance membership card is worth it's weight in gold.
#16 ·
I have to second the bicycle pump, very easy to do and that's from experience. I've pumped up my scooters tires with a "stick style" pump from almost dead flat with fix a flat in it. Took about a minute and a half to get to 30psi, an electric pumps takes just as long or longer including set up time. Also the stick style pump is easier to store compared to a cube shaped pump.
That all being said I'd recommend a product I started using last tire change on my scooter. It's called "ride on" http://www.ride-on.com/motorcycle-formula-mot.html works like "tire slime" for puncture plugging bug it's more gel like so stays in place once slung around in the tire and balances it as a side effect. $30 for 16oz and you need only 5 oz in each tire. So enough for one front and two rears.
#19 ·
There's definitely more than one way to skin a cat or fix a flat. All have pros and cons. When I ride the bicycle I use the little CO2 canisters because they're quick and easy, but they are a one-shot deal and if you mess it up you don't get a second chance. I'll pack a way to repair a puncture, but I'll also have my insurance policy number in case I need to call for a tow. Hopefully I won't need either.
Forecast is for rain next weekend. Let's hope they're wrong. Looking forward to ripping up some curvy mountain roads on the Grom!
