Hal's Grom
43K views 90 replies 27 participants last post by  Volvo
#1 · (Edited)
Hal's Grom 235
Honda Grom 235cc
Imgur Album
On Bike
Antigravity 8-cell 12v 4.6Ah Battery
Area 22 Billet Side Covers
Biker's Billet Clutch Adjuster
Brock's Alien Head 2 Full Exhaust
Chimera Fairing Support
Chimera Short Ram Intake
Corbin Seat
CR Racing Brake Fluid Reservoir Cap
DID Professional Series O-ring Chain
Renthal Fat Bar (RC High)
Renthal Fat Bar Clamps
Driven Cam Cover
Driven D-Axis Mirrors
Driven D-Axis Rearsets (GP Shift)
Driven D3 Grips
Driven Handlebar Weights
Driven Inspection Plugs
Driven Sprocket Cover
Driven Tappet Covers
Endurance Billet Handlebar Clamps
FinBro Custom Programmed ECM (full Thai spec harness)
FinBro Ported Throttle Body and Manifold
FinBro 235cc Complete Motor (forged piston and crank)
G-Craft Billet Gas Tank Cap
G-Craft Billet Rear Reservoir (Type 3)
G-Craft Multiplate
G-Craft Billet Shift Guide
Gold Plug Magnetic Oil Drain Plug
Honda 10-hole Fuel Injector
Honda Arctic White Fairings
Koso DB-03R Multi-Function Cluster (SMD mount)
JILLS Billet Clutch Cable Holder
JILLS Billet Fairing Bolts
JILLS Billet Throttle Cable Separator
JT Sprockets JTF252 16T Steel Front Sprocket
K&N Air Filter
K&N Waterproof Air Filter Wrap 22-8028PK
KCP Billet Boomerangs with LED Running Lights and Indicators
KCP Billet Chain Adjusters
KCP Billet Wheel Spacers (Front and Rear)
Kitaco Billet Key Cover
Kitaco Billet Starter Motor Cover
Kitaco Crank Case Cover (Integrated Oil Filter)
Kitaco Hollow Axle Shaft (Front and Rear)
Kitaco Super Oil Cooler
Koso DB-03R Multifunction Cluster
LED Flasher Relay
Michelin Power Pure SC 120/70/12 Front Tire
Michelin Power Pure SC 130/70/12 Rear Tire
MNNTHBX / CARD Full Race Fork and Triple Clamp
MNNTHBX / CARD Rear Shock
MNNTHBX Fender Eliminator with LED Tail Light and Indicators
Moose Racing Billet Gas Check Valve
MRA Smoked Windscreen
RAM X-Grip Phone Mount
Ricky Stator High Output Stator Kit
Right Angle Valve Stems
RPM Billet Clutch Spring Plate
Sex Machine Racing Clutch Springs
SBL LED Headlight Kit
SBL Shorty Brake / Clutch Levers
Southern Mini Designs Koso Multifunction Cluster Mount
Spiegler Stainless Steel Front Brake Line
Spiegler Stainless Steel Rear Brake Line
Takegawa Super Oil Pump
Tyga Black Lower Cowl
Tyga Carbon Fiber Shroud Vents
Tyga Carbon Fiber Tank Cover (Replacement Type)
Tyga Carbon Fiber Under-Tank Covers (Replacement Type)
Vortex 32T Aluminum Rear Sprocket
Vortex Hydraulic Rear Brake Light Switch
Wemoto Starter Motor
Yoshimura Billet Steering Stem Nut
Other Stuff
Clutch sensor delete
Evap canister delete
Horn relocated to air box mount
IAT delete
Kickstand sensor delete
Oil spinner delete
On Bench
Sex Machine Racing Clutch Discs
Removed/Replaced
Bosch 17018 O2 Sensor
DynoJet Digital Air/Fuel Gauge
DynoJet Power Commander V
DynoJet Wide Band 2
MNNTHBX 35T Aluminum Rear Sprocket
MNNTHBX Faux Frame
Ohlins Fork Internals
Ohlins Rear Shock
OPMID Cylinder Temp Gauge
RPM Billet Gauge Mount (2 Gauge + Button)
RPM Clutch Springs
SpeedoDRD Speedometer Correction Device
Wanse Trading Belly Pan
#14 ·
I don't really keep track of what I spend on this thing, to be honest. It's literally mentally categorized as a "money black hole toy," haha. That being said, I've pestered ARunto quite a bit with questions since he has a lot of the same mentality on setup.
I only got the 218 motor coming so I can keep up with bigger bikes on longer rides because I think it will be hilarious and humbling.
It honestly makes me laugh whenever I ride the Grom and it even makes it more fun to ride my bigger bikes afterwards. Sometimes you lose track of how cool it is to have 170hp on the Diavel, but an hour of riding the 10hp Grom makes the next Diavel ride a wheelie fraught hooligan experience. If that makes sense?
#28 ·
Finally got to 300 miles on the new motor. Did the oil change and swapped in the GoldPlug oil bolt, Takegawa super oil pump, and Sex Machine clutch springs. The springs are 30% stiffer versus the 10% RPM ones that I replaced. I didn't replace the plates yet, I'll do that at 600 miles.
Then I had a nice ride with the wifey and nothing blew up, so I live to Grom another day.
#34 ·
The fuel cap mounts to the OEM plug and lock. You just flip it over, pry out the little steel disc that covers the screws, remove three screws, and the top cover comes off. Then you use the same three screws to fasten the G-Craft plate on, replace the steel disc, and you're done. The only annoying part is re-seating the rubber gasket around the little steel plate. It's not difficult, just tedious.
As for how it functions, it's perfect. I love the look.
