Allows you to remove the baffle and make it LOUDER
nevermind, you can remove a piece out of the muffler. remove the allen screw from the end of the muffler, have to remove the little rubber plug on the carbon tip to get to the nut. The inner sleeve comes out from the inlet side. Then take a bearing puller and remover the little aluminum restrictor.i removed it, its really nothing, it just allows a smooth transition from the packing to the exit of the muffler.
Got a picture of what your talking about removing? I took out the screw on mine, but can't seem to take out the darker annodized section out. I'm not using a puller though. I will, but am not sure exactly what I'm suppose to be taking out.nevermind, you can remove a piece out of the muffler. remove the allen screw from the end of the muffler, have to remove the little rubber plug on the carbon tip to get to the nut. The inner sleeve comes out from the inlet side. Then take a bearing puller and remover the little aluminum restrictor.
yes the stainless pipe comes out, but you have to get it out from the inlet side of the muffler. And then use a puller of some type, i used a habor freight bearing puller, to get the 3.5" anodized bezel/ring thing outMine's is really in there. I guess some parts are machined tighter than others. I bent that spring hook, and tried to make something along the lines of a dent puller. It didn't budge. Show me what the parts are that came off. I can figure out the rest. Was it the stainless 1" pipe and the larger 3.5" annodized bezel/ring thing-a-ma-jing?
Here ya go. The grey ring on the shiny pipe comes off (I run mine with the grey ring still installed, but without the sleeve).So today I removed the screw from the baffle and attempted to pull it out. Whilst trying to pulling it out It looked the metal pipe slid back into the can (F*&!) Does any one mind showing me a picture of their baffle? I would really help to see what I'm trying to take out.
Right now I need to figure out how the hell I'm getting it out......
my new Grom has an rs9 and I tried to remove the baffle todayHere ya go. The grey ring on the shiny pipe comes off (I run mine with the grey ring still installed, but without the sleeve).
First, this is a really old post, so don't expect a reply from people you quoted.my new Grom has an rs9 and I tried to remove the baffle today
i found that only the shiney pipe came out via the inlet but the grey ring stayed put, which is fine as it's plenty load like this.
so with the shiney pipe out and grey ring in place do I still need to use the screw to secure the grey ring ?
and if I want to install the shiney pipe again how do i install it ? Pop it in through the inlet or can I push it down via the outlet ?
Sorry for the the questions but the bike didn't come with the manual for the yoshimura rs9 and Google doesn't show much about this.
thanks.
Thanks for the fast replyFirst, this is a really old post, so don't expect a reply from people you quoted.
Second, I love Yoshi pipes, definitely my favorite pipe.
Third, hahaha, getting the baffle out of any Yoshi pipe is a biatch! Slide hammer is the easiest best way. Took me a few bikes and Yoshi systems to learn that. Slide hammers are cheap, $20 from Amazon of Harbor Freight, etc. I don't have the Yoshi on my Grom, but they're all pretty similar. Keep that screw, get a slide hammer, and once you have the hammer, reinstall that screw a little bit, but not all the way through, and attach slide hammer to that, and start softy hammering it out. It'll come out. Sounds like your baffle broke, and that's why it's in two pieces. If I'm understanding your post correctly anyways. Once out, you might be able to have it welded back together, or order a new one from Yoshi directly. Once out, you'll probably just leave it out and not want it back in to be honest. It's not that much louder.
