1 - 9 of 9 Posts
Hey guys I picked up a Yibid LED integrated Tail Light, I hooked it up best as possible. I got the running light and break working with the signals but the signals don't blink. I read the instructions and realize that I need to use this orange block to control the blinker. I'm just not sure where it goes? :sorry:
The instructions are in broken English but kinda of still straight forward I just wish the had a diagram of how the flasher box was hooked up.
  • Brand New Taillight assembly With 1pcs 2-pin Orange Led turn signal flasher relay(B pole=Input,L pole= output---Must in Right connection or Not Blink!!!) ;No instruction! Need to install skills,Professional installation is Recommended;
  • Package Included: 1pcs Taillight assembly & 1pcs 2-pin Orange Led turn signal Flasher relay (NO taillight Relay Including!!! you can used your store one) Fitment :For MSX125 CBR650F CTX700 CTX700N
  • Wire Connection: Black Line:Negative ;Red Line:Red Lighting(Brake light) :Blue Line:Red lighting(Running light) ;2 *Yellow Line:Yellow(Turn Left/Right Light)
  • Note!!LED light usually use little bit power, sometimes after you install, the LED light blink so fast or not blink, if you have this issue, you may need LOAD RESISTOR to put between the LED lights and POSITIVE, usually go around 6 ohm LOAD RESISTOR will,make it work
Discussion Starter #6
How do you like it? I've contemplated one but never heard good things about the cheap ones.
Honestly not a single issue, super easy install and it looks great. visibility is also great... obviously not compared the the shrek ears for signals but I love it.
New to this bike and not sure where the Yellow wires connect to or how to connect them. I installed everything else but the yellow wires. May someone be some assistance in what is needed to make the turning indicators work? Thank you :)
1 - 9 of 9 Posts
