1 - 17 of 17 Posts
Hi All,
So hears the deal, im trying to make my grom breathe better in the higher RPMS... i currently have a kitaco type 1 cam. Looking to see if anyone has a more aggressive cam they want to get rid of. If show post up or shoot me an offer.
~Nd4
I will be taking the finbro cam out of my 183cc but I am not sure but it may have to much lift. Do you have the stock piston. Or bbk?
if youre feelin' real squirelly, I have my old stock head and yuminashi cam, valves n high tension springs. this has the longer valves in it,(lift was 7.1? mm) it breathed really well. head and cam 180 shipped conus. basically the only part of the kit that didn't suck balls.
I would sell you a Kitaco Type 2 cam from my stock head for $40 shipped. Roughly 2k miles on it. I have been running 170 4v for awhile now.
Discussion Starter #9
check your PM.
So far the type 2 is on the list, But i gotta think about it, i might want slightly more agressive than that. Like i told gdublug a day or so to see what others have. I also want to find specs on the type 2 vs type 1 to see what the differences are. But kitaco does make a good product.
Kitaco cam specs are on the webike pages (id find and post, but at work), as well as some dyno charts (I think its on the type 1 listing, but for both).
I've never been able to find the specs on the type 2. Even tried the Japanese site run through Google translate. Would love to see them if someone finds them.
From webike:
Type 2:
Valve Timing Angle (When using STD Cylinder Head)
IN Valve: OPEN 8-degrees BTDC/CLOSE 46-degrees ABDC
EX Valve: OPEN 40-degrees BBDC
Type 1:
Valve Timing Angle (when using STD Cylinder Head)
IN Valve: OPEN 7-degrees BTDC/CLOSE 36-degrees ABDC
EX Valve: OPEN 37-degrees BBDC/CLOSE 9-degrees ATDC
Emphasize valued at medium revs Power surge type1, Type2 is at a high rpm Power surge
Link to info and dyno chart comparing the two cams:
http://japan.webike.net/products/21694533.html
Discussion Starter #13
Type 2 cam specs are
Intake Duration is 234.00 degrees.
Exhaust Duration is 232.00 degrees
1mm more lift over stock
Type 1 cam specs
Intake Duration is 223.00 degrees.
Exhaust Duration is 226.00 degrees
Makes sense why the type 2 is more of a high end cam, decent amount of overlap for extra scavenging etc.... hmmmmmm decisions decisions.
I might take the poster above up on his offer here.
Though yosh cam specs are even bigger! haha.
So...what are you doing with your old type 1? I'm interested.
1 - 17 of 17 Posts
