1 - 20 of 33 Posts
You high-mileage riders have the best experience to tell the rest of us what to expect. Any parts failures? Anything wear out or have to be replaced earlier than expected like tires, chains, sprockets?
At 8000 miles the rear tire is down to the wear bars. Probably would have lasted a little longer if I didn't do any burnouts lol! On one occasion around when I had 2000 miles or so the bike had a hard time going into neutral. I checked the clutch adjustment but it was good. So I just changed the oil out and kept on riding it and the problem want away and it has never come back. Other than that the bike has been great, no major problems. I ride 50 miles round trip everyday to work and WOT 90% of the time and on my way back home is 10 miles uphill. Chain is also in good condition, I check and lube it regularly and only have had to adjust it twice.
Sent from my iPhone 6 using HondaGrom.net
Wow, Strokd is going through some rubber. I doubt I will be through my first rear tire by 6000 miles. Your chain is still going though. Mine was rusty and stretched out by 2500 miles so I am on my second. I guess everyone knows the chains are crap, but I am reassured there are no major mechanical problems so far.
It does if you don't wipe the excess off. Stinky stuff if he's using synthetic. I might start using gear oil again, but I like a spray to clean off the chain first and have just been using a cheap Walmart brand of WD40 to clean the dirt off as well as lube it. My chain rusted after I got it wet but nobody else seems to have had that problem. Maybe I need to switch chain lubes too.
I know this is an old thread, but who has the high mileage groms now? Would love to hear from you all with 15k plus
WD40 is a HORRIBLE lubricant in general, it is better than nothing but not much. It is way to light to for use as a chain lube, it is EXPECTED that you would get really short chain and sprocket life using that. WD40 means WATER DISPLACER, and was not designed as a lubricant. Many people started using it incorrectly as a lubricant because it was easy and looked clean, and the rest of the monkeys followed suit to propagate a bad idea.
Chain lube is generally pretty bad, as MARKETING is their primary goal, making it totally clean and pretty looking, with good lubrication being second. So chain lube lubrication properties are not that great.
If you want your chain to last a long time, use thick gear oil or grease. Its not all pretty and clean, but it will protect your chain very well and make it last a lot longer.
Mike
I find it kinda funny how I am close to 15k now and I posted the question with less than 6k in May
1 - 20 of 33 Posts
