1 - 20 of 24 Posts
Just from racing and riding with friends that have the Takegawa 181-4v super head I say that is the one to get. Friends with that engine would walk away from my grom even with my BrianS 170 or my Finbro 183 engines. I felt like I was standing still when they took off and I have a pretty fast grom I thought until I rode with them.
The only two other BBK kit grom engine that I thought was worth getting that have bo-Ko power is the Finbro 218-2v stroker and the Finbro 235-2v both using Finbro provided ECM and wire harness, type B 6 hole F/I and the larger gas hose. Boy those engine have a lot of torque but they create a lot of heat and have know to fail due to owners not controlling the heat by having a external oil cooler or having a engine brace to reduce the vibration that engine creates
The Takegawa works. Made in Japan, and high quality. Once I took over control of the timing, I have had 0 issues. I did break a stock crank at 2,000 miles with the Takegawa kit. It had an additional 2,000 miles with the Finbro 183 (4,000 miles total on that crank). I have 2,600 miles on the Takegawa kit, and still have the same cam chain tensioner for all 2,600 miles. It's like the one that Finbro offers.
You won't be disappointed in the build quality or power. Get a carb, apply GSX's cam chain wheel solution and you'll have a great package.
GSX, if I pull all the additional timing out of the Power Commander, will I be able to get by with 91 octane pump unleaded? The Takegawa 181 4V has a compression ratio of 12.5:1.
I don't know where the factory ecu has the timing set at. I threw it in the trash. I think it's part of the problem.
I ran non ethanol 91/93 with no timing added in my 181 4v. Mixed it 50% with VP T4 for extra octane during break in and making maps just in case I got near detonation.
If you are gonna run the koso 34 with a pod type filter, I would suggest you get the silicone intake pipe that Steady Garage makes specifically for that throttle body. Takes a filter with a 2" ID. I especially like the more plenum like shape it has over a standard single diameter intake pipe.
At this point, I would be inclined to use a PCV/WCB2 and a 34mm throttle body.
Will the K&N R-1100 fit directly onto a 34mm throttle body, or do I need a different air filter for it?
I lost power/ top speed and fuel trims pulled back on my PCV/WB2 when I ran the filter directly on the throttle body. ImageUploadedByHondaGrom.net1470400947.726239.jpg
Do this instead. Go to silicone intakes.com and order 1 135 degree hose, and one aluminum tube. Cut the aluminum tube shorter and fit as pictured, get a K&N from a Chimera, and you're all set. Top speed increase of 3mph or so.
EDIT: K&N RU-2580 is a Chimera filter without the cheesy chrome top, it fits both on the intake pictured and the 34mm throttle body if you're so inclined.
The best I have access to is 91 pump unleaded containing 10% ethanol.
Our riding area is from about 3,000 feet elevation up to about 6,500 feet elevation.
That elevation will help, less air= richer mixture. Someone correct me if I'm wrong, but ethanol added does burn cooler and won't detonate as easily, right? I run non ethanol because it makes a bit more power and gas/ethanol mixtures go bad quickly, I've rebuilt many carbs and replaced many fuel pumps because of it.
That being said don't be scared to run ethanol fuel- it won't hurt anything as long as you don't let water get to it or let it sit for long periods.
What fuel injection?
Is this really what it looks like? Oh my.
For reference, pure ethanol is like 100 RM/2 octane rating, and its auto ignition temp is around 700F. (Normal gas is around 500F) As far as combustion temp... I want to say it burns cooler too, but im just guessing.
Dont Indy cars run Ethanol now?
Also, as a note on the altitude, at higher altitudes, you can use a lower octane. Higher altitude -> less dense air -> less pressure at tdc (from the fixed pressure ratio) -> and less heat produced
For something like this (well on a 'performance' engine), id still stick to the higher octane. Why risk it?
1 - 20 of 24 Posts
