1 - 7 of 7 Posts
I'm looking at a 120/70-12 POWER PURE SC 58P TL MICHELIN for the front and a 130/70-12 62P POWER PURE SC TL MICHELIN for the rear. Are those the correct tires to directly replace the stock 2019 Grom tires?
Those will work but you don't need such a high load capacity, same tires with 51P front and 56P rear are recommended by Honda and Michelin (instead of 58 and 62).
Thank you.
I'm running these exact tires, good to go.
I've been using Michelin Power Pure 120/70-12 on the front and 140/70-12 on the rear since 2014-15 time frame with zero issues. If you keep your air pressure at 28psi your tires should last a long time.
Discussion Starter #6
It looks like I can only get the Michelin 130/70-12 POWER PURE tire with the 62P rating here so considering that what would be the better front tire to get in combination with this rear tire, the 51P rated tire or the 58P tire or does it matter?
1 - 7 of 7 Posts
