1 - 2 of 2 Posts
I'm thinking of swapping the throttle body and have a few questions:
1) Do I need to de-pressurise the fuel system to swap over the injector or just leave injector attached and then fit it after to the TB once attached?
2) Do I just pull the tps off and put it on the new one (The koso 34mm doesn't come with one) (worried about this as the tps if factory preset to the TB).
3) Is it literally bolt off old one and bolt on new one (obviously reattaching sensor connectors and injector).
Cheers
you need the intake, connector to airbox or othe rair filter, and even then your head port wont match.
yes you use the factory tps, reset the ecu
just unplug the line from the injector. you'll need a larger one anyway. (injector, not line)
but the 34mmtb is really for more modded stuff, unless you already have a modded motor. if so, then see above.
1 - 2 of 2 Posts
