I upgraded and got a Barnett kevlar clutch and with springs and pressure plate, along with oil pickup. Everything seemed to go back together well and the bike is able to find neutral and shift through the gears while the bike is off. When the bike is on and clutch is pulled the bike starts in neutral but jumps forward and stalls when I shift into first gear with clutch still engaged. I have adjusted the tension in the clutch cable so the clutch is SUPER tight, as well as loosened it to have slack, yet the results are the same...
Any issue what could be causing issue? I know from watching other install videos that the clutch bearing is flipped the wrong way with the letting facing inward. Could that be causing the issue though? Have seen issues on here with the clutch slipping, but not for always engaged.
