Friday night I installed a UNI air filter directly on the TB and completely removed the stock air box. At first there was a hesitation but now it seems to be running great. I have about 30 miles on it this way. I can't really tell if I gained power or not. I will say this little sucker is loud, so it feels faster due to that anyway, it's rather deceiving. The install was smooth. I just unbolted the airbox and tossed it aside. Then stuck a cheap breather filter on the crankcase breather hose. I bent a cable bracket around instead of cutting it off incase I want to return to stock again. The filter went on without a problem. When I was installing the right hand shroud it kind of rubs on the filter. Looks off to have a red ball of foam stuffed against the shroud. I need to look it over and see if I can turn it so it doesn't look so out of place. I'll get some pics when I get a chance and it's not so freaking cold out. Anyone else go this route? Looked like its stuffed in there all funny? I'm worried it will wear through the foam how I have it... I have stock exhaust by the way, so wasn't expecting a huge gain.
