Hi all,
Decided to give the TYGA tail tidy an install attempt yesterday. After dropping one of the OEM bolts in the frame tube (crap), I encountered some other questions / issues:
Anyone experience similar problems? I loosened the exhaust bracket, the exhaust can be placed another 1,5 cm lower to clear the indicator. But once I tighten the bracket nut of course everything goes back to it's original place (too high -> hits the indicator).
Are there different 'lower' brackets available for the OVER exhaust? Would be a shame to have to ditch the TYGA tail tidy in order for something that is compatible (hotbodies perhaps?)..
All suggestions are welcome!
- The blinkers have a yellow and black wire each. The connector (female) part that's attached to the thicker black wire has a clear indicated yellow L and R female end. And two unmarked black ends, so I just put one in each of them. Is this the correct way to go?
- Flasher relay: don't exacty see where and how to install this? Does this replace an exisiting relay?
- Bolts to tighten the blinkers are oddly designed / placed IMO: you can hand tighten them, but no wrench size 13 I own fits in the carbon piece to REALLY tighten the bolts.. So those will probably come loose on the first few rides.
- Biggest issue: my right blinker is not compatible with the OVER exhaust that's mounted on my Grom, so this happens:
