1 - 4 of 4 Posts
Hello all
I'm upgrading my Grom with a Kitaco Neo 180cc kit with very little experience and the service manual ^^
Gearbox fell out while I was changing the crankshaft for the kitaco renforced one.
I've putted al the pieces back where they belong and everything fits but I do have one question, service manual isn't clear about this, :
How do I know if the gearbox is in neutral position before putting everything back together around it?
If I move the gears around, everything turns so I don't know how to set it or how to find neutral
Thanks in advance for your help. And sorry if it's a stupid question ^^
  • 87009
    87010
    87011
If all the transmission parts went back in it's place I would not worry about neutral at all. If you are really worried about neutral, after putting both crank case together just look in the neutral sensor hole and see that the spring loaded pin is lined up with the sensor contact.
Good Luck
1 - 4 of 4 Posts
