1 - 20 of 145 Posts
My top speed 72mph
Tucked, mild winds
118 pound Guy
Low mount exhaust
Drilled holes on the plastic and rotated pipe forward
Fender delete
70 full tuck,flat road and no wind or drafting...I Cruise 60+ sitting up on flat roads with no problem..
170 lbs
Full Yoshi
Ejk
Radiator hose intake mod wit uni filter
Stock gearing.
Braap
You guys are moving!
66 mph with no mods, tucked. I weigh 138 lbs. 66 mph is well over redline which is at 62 on my bike, so that is as fast as I routinely go, but I go 62 mph also in a tuck a lot on the interstate basically until I come to a hill that shows me down. Without a tuck, my highest speed is 58 mph....level road. Wind and slope changes everything.
155lbs, 6', few mods, 65/68 upright, peg out around 8,700 rpms, just not enough umph to push past.
I'm sure if I tuck/draft then I'd go faster, but I'm form over function as long as I can still push 60 mph uphill.
Add: Optimal conditions, no wind, 60's, no hills, small bends. I don't hit 65/68 on the highway with regular traffic without drafting some.
Add: And 14T so my speedo is obviously off.
Sent from cell. SPARKLE.motion
I've hit indicated 73 mph, flat road, no wind, full tuck and I've done 70mph indicated sitting up. I'm 130lbs. Only mod was a Tyga exhaust.
My redline begins at 8200 or so which is 62 mph for me. That's nearly wot and that's my benchmark. If I edge up over that speed, I slow down a bit. I do have one mod on my Grom. I put in the high speed spark plug since I do a lot of interstate riding. I don't think that affects speed though. The fastest I've had my bike is 66 mph and I think that puts me at 8500 rpms. Usually this happens on the interstate with a little downslope or tail wind. Really, I could just ride WOT all the time and not redline and control my top speed by how much I tuck. I-35 around here is nearly level.
when my bike was stock I went 63 tucked, I've seen 65 tucked on the highway after doing a foam air filter and the rest of the air filter mod. this weekend I should have a higher number I will have exhaust and a 14 tooth front sprocket. need to download a gps app so I can see my actual mph
1 - 20 of 145 Posts
