1 - 8 of 8 Posts
the main problem is I own the only grom in North cyprus they have no experience here with these kind of engines! I am afraid that the engine will break up
I’d say for people to help more info is needed like who is the reflash ecu from and even a video of the bike running with ticking sound would be good.
Reactions: aliradwan
Proabably needs a valve adjustment, the air box blocked most of the sound. Now that it is gone, you can hear the valvetrain noise. How many miles on the bike? When was the last adjustment done?
ticking usually indicates valve adjustment, definitely check to make sure your valves are in spec.
Just did the adjustment last night and it still making the same sound , I will upload the video soon i really appreciate it
Discussion Starter · #7 ·
While re doing the adjustment I found a scratching on the value caps, I think its from the value hitting the value cover ? I will adjust it again tomorrow, this grom page is great 👍
While doing the adjustment I found scratches on the valve cover from the inside!! Adjusted it but still Making the ticking sound
If you don't have a feeler gauge then you can use the other method which is to tigthen the
You haven't got a loose nut in there?
1 - 8 of 8 Posts
