1 - 20 of 40 Posts
Mine needs it badly. I can do a whole half turn of the throttle before it kicks in.
oh i'm sure! they are all like that.
what i meant was, does there really need to be a "how to" thread? it's take your right side plastic off, 1 nut to loosen, twist the cable out and tighten nut lol
For a non mechanically inclined person such as myself, YES :)
How did you loosen the back nut without taking the black cam shield off?
^this
UPDATE: just went out and adjusted it, it was easy and I did not have to take any plastic off.
Just use a small 10mm wrench to loosen the bottom set-nut up and then with your fingers squeeze them up in there and turn the cable nut counter-clockwise till your throttle slack is where you want it. and then tighten down the 10mm set-nut.
I have mine set at 1/8 inch of slack.
Uhm. Why not adjust the cable on the lever? You take the wrench and turn the top nut left or right to adjust cable length.
1 - 20 of 40 Posts
