2841 - 2861 of 2889 Posts
87729
Did a lot today.
Today was the first oil change, at 630 miles. Quite a bit of debris in the oil and in the screen. Glad to have a real filter now. Will probably only give it 200 miles, then do another oil change and pop the cover off to check the screen again.
With the new oil came a new oil system.
Kitaco Clutch cover.
Magnetic Oil Drain Plug
30% stiffer clutch springs
Chimera Billet Clutch Plate
Takegawa 4th Bearing
Drilled the oil hole mod for the 4th bearing
Takegawa Cam Chain Tensioner Arm
Kitaco Duracon Cam Chain Tensioner Cap
Tomorrow gonna go for:
Kitaco 5 Row Oil Cooler
Kitaco Oil Catch Can
I would say no need to pull the cover again at only 200 more miles, the screen will be nearly spotless at even 1000 more miles. All you seen was from the initial break in, which is why a good first service is so important.
Agreed, I'd go as far as to say it will be nearly spotless at even 10000 miles more, that is if everything inside the engine is ok of course.
As for the ''real filter'', there is nothing wrong with the centrifugal filter, some might find it more convenient but that's it really (appart from the supposed added performance). There's no proof the paper filter will do a better job, if anything I wouldn't be surprised if the centrifugal filter performed better.
I agree the centrifugal filter works fine, I was amazed at the crud in it at my 500 mile oil change. However, I do not think it would catch the rubber pieces from the cam chain tensioner if you had one of those start to fail. I would highly recommend the kitaco or takegawa cover to someone interested in a little extra insurance. It was the very first part I ordered for my Grom because I anticipated high mileage in my future.
Racing Bros Fork kit went in on Saturday!
Much better... Although, maybe a tad stiffer than I want.. I could see myself in a while, once everything else is done, gabbing some .60 springs to put in.
Grabbing a handfull of front break no longer bottoms out the forks... lol
Have a matching Racing Bros shock to put on as well. Just waiting on getting the spring back from the powder coating place.
87775
87776
Monkey rearsets. V2.0
So my first attempt at swapping out to Monkey rearsets to go all Black, was not a success.
Got on here, made a post and then was directed to tooter's grom thread and how he was able to make them work.
87798
Ordered the Monkey break pedal, a second right spring, and bought some 12mm cut washers.
87799
Before
87800
After.
This time it worked out. Looks much better and can use the brake now.
I will say though, that I still wouldn't call it a perfect fit, but it's close and for sure usable. Down the road when everything else is done, I may look into made for the Grom aftermarket rearsets, but they're expensive and I've got other things much more important to me right now for the bike.
finished with my install today biked turned over for the first time today and rode it, it is a huge difference in power must i say. things i installed dhm 186 kit and takegawa crankshaft and power shin yea starter motor, i tried to turn it on with stock starter but that didnt work but it did with the power shin yea with at ease.
Would you mind linking the starter you bought. I've been in the market for an upgraded starter since I went 186 as well. You can get some pretty good speed out with different gears. 83mph for me so far with 17/32t gears
i put new rims with tires on. and failed bleeding my front blue core ss brake line.
spent 300 for tires rims takegawa 181 s cam fcon2 and stock head
87897
I noticed that Koso offers a starter now too. I think is costs like $200 though. Yikes. I would probably go with the Kitaco.
Do you know if those rims are any lighter than stock?
I was going to check but I did. Considering I'm going to change the rear roter I can balance scale the back tire
New TST captive chain adjusters today. Worlds easier to adjust, simple install. Also did some Chimera wheel spacers at the same time, much smoother, front and rear.
Got a PitBull bike stand.... but....
Does anyone know of a Grom sized bike stand? It would be nice to not have the rear 12-18” higher than the front. Lol
87915
87916
87917
87918
87919
I’m using a vortex front stand with the 20mm pin for the grom
