2741 - 2756 of 2756 Posts
I stopped to a bar and drank a couple of beers. Bike won't start at all, starter dead. I suspected a kickstand switch problem so I asked barmaid for some scissors and i cut cable and shortened circuit. Nothing. I swerved a lot then I randomly inserted my hand where the starter motor is. I found a free cable.. Basically vibrations had unscrewed the bolt who keep positive cable in its position too much vibrations. That's all
86252
86253
86254
Had Ohlin carts installed in the forks and an ohlins rear shock.
Put on power pures and EBC oversized rotor kit with front and back HH pads.
The ohlins make a huge difference. The front does not dive under braking. The power pure tires are excellent and don't slip and slide around like the stock tires.
Installed Chimera intake and the Hindle pipe with silencer.
Installed an Aracer mini 5. Bike runs noticeably better and faster. AF1 module coming in a few days so I can get auto tune going for an even better ride.
Magura 12mm front brake master and ss line on the way.
Kitaco clutch cover in a box waiting for install. PSR pegs as well.
Ordered a kepspeed swingarm.
That should cover my bucket list until I decide to go big bore.
Would love to try these sato rearsets. Better than the driven sets; they have a hanger for the low pipes and use existing brake light switch. Driven has neither of those features.
86255
86256
Just ordered the new TST Tail Light. I’ve been wanting a bright integrated light for a while, but wasn’t a fan of their first version. I like the MNNTXB tail light, but wanted to keep that OEM look. This checks all the boxes.
You'll like it. :) It's really bright.
I ordered the whole TST Kit the first day I got my Grom.
Installed the:
Kitaco clutch case
86273
Koso Clutch Plate
86274
Heavy Duty Springs
Dominator Clutch cap on my Brembo LHRB setup
86275
Rides great. Spent some time getting the auto tune populated. Aracer makes a very cool product.
Ordered a TST tail tidy and front flush lights.
Installed Pro taper bars but removed the center support for more room to mount accessories.
Installed a 12mm magura radial front master. Outstanding mod. Really great feel. Much more modulation compared to stock master which feels a bit wooden.
Stainless spiegler line but that line needs to go back since the top banjo angle is too acute for a good run. Works for now.
Put a Domino grip on the left bar end but could not get it on to the throttle tube, so stuck the stock back on.
86319
Added a serape “ Mexican style blanket” and the white walls. I really digging the new look. Also added a 37t rear sprocket. And kept the 13t front sprocket. 😮. If you have been thinking about it. DO IT. GET THE SPROCKETs!!! ( will need a new chain). That thing launches at every red light and stop sign. And wheelies are now 10x easier. I’m definitely going to loop a couple times.
But the goal is to get good at wheelies. Main reason for the sprocket change.!!
Installed TST fender eliminator kit, integrated tail light, plate light and relocation bracket. Nice kit!
86332
Installed the TB Cam. Recommended. If you mostly ride the Grom at WOT, this cam seems to provide more overhead in the RPM range.
I was hitting the rev limiter at points in the ride that previously were a couple of hundred RPM below limiter in the same conditions, same spot on the road, same transmission gear, same throttle position.
Rode it some more!
And ordered an o link chain, rear sprocket, wheel spacers, axle sliders, short throw throttle tube, and plugged a puncture in the rear tire.
When not modding, I actually ride this machine.
Love this hill.
