2721 - 2733 of 2733 Posts
ah installed a triple led headlight, took a while with the wiring
I've been trying to find the factory plug for the SF headlight. Id like to be able to put a small LED bar below my number plate and pug into the factory wiring. That way I don"t have to change out the number plate every time I wanna take the bike on the street for a quick run or bike meet.
Played with one of my spare headlights last night, added some RGB LEDs to the inside...
Testing...
All done!
Just have to aait for my controller to come in tomorrow and then i can make a video of the color change
FINALLY got around to installing the PCX injector and re-installing the Yuminashi Powersport ECU. Need more seat time to get the low rpm sorted but damn what a difference above 7-8k! Thing pulls MUCH better than before on the manual tune Yuminashi ECU (newer version w/ BT). I am sure I could have gotten a dyno tune and been happy, but that would only last until the weather changed. These ECU were stated to have no rev limit, but I seem to be getting one around 11-11.5k ish. Or maybe it just needs more time up there to tune itself. The Automatic tuning is what drew my attention in the 1st place. Time to get this thing back to the track I guess, poor thing never gets ridden anymore since I got the 390 Duke (way too much fun for the streets).... :cool:
Mine takes about 60 miles to adjust itself. :)
$15.00 exhaust guard:. I've been worried about the exposed exhaust when going off road.. Unable or unwilling to pay $200.00 for a skid plate I have purchased a 60cm guard that along with 3
1 1/2" hose took roughly 45 minuets to install . That included the pre bending and final crimpin. 20191212_125329.jpg 20191212_125252.jpg 20191212_115012.jpg
Been struggling to fit these hand guard. Whoever tightened the Banjo fitting for the reservour must be a mutant. I can loosen the bolt itself but;...Unable to prise the length of metal attached to it, to an angle far enough from the handle bars that I may attach the lower portion to the hand guard bar… Grrr (heavy handed factory workers)~!
PS the oil drain plug was also torqued down waaay too much! One extreme or the other... . .
^^^^ I only have about 10 miles on mine so far since swapping the ecu and injector, but every time I fire it up and go for a spin, it feels like it is doing its thing and running better... Probably should have also mentioned, I have a lightly ported head, Yuminashi Hi-lift cam and special double valve springs/retainers that go along with it, and a ported stock throttle body too, which is why I an revving so high. Takegawa light weight oil spinner should be here today as well, going to make this thing run like a two stroke eventually, or blow it up and swap a 125 two stroke into it.... ;-)
ever find out how? i like that look as well
Made a Koso gauge dash that's a lot lighter compared to the billet one (gained around one pound!) but that still looks OEMish in some way.
Bought a cheap chinese OEM looking Grom clone cluster (26$) as I didn't want to destruct the OEM cluster (used the mid and lower parts only) and used a piece of carbon and a few screws I had lying around. Some drilling, dremeling...
Pretty happy with it! I could have used recessed bolts but the carbon sheet I had was only 1mm thick so not enough meat for it, 1,5mm or 2mm would have been better for that.
85952
