1 - 15 of 15 Posts
My list of updates as of today. I ordered the full Yosh list of parts. The FE, bar ends, swingarm spools, large and small engine plugs, steering stem nut and a full Yosh carbon/carbon system. Anodized red plugs and steering stem nut.
Sent from my SGS3 using HondaGrom.net mobile app.
Discussion Starter · #7 ·
Also fyi in regards to the FE the stock wire going to the license plate light is only putting out ~6VDC and will not power the leds. I cut into the rear brake light for power. Has anybody noticed this?
I have the FE and I used the stock brake light wiring. Never touched anything else.
I had issue with tag light power,and really did not like how far it was sticking out. So I went with Composimo version. As for there stand stopper kit, it was disappointed to see they want you to drill the swingarm to install(2) 4mm bolts. I choose to just replace the jam nut with a Nylock one( now there is no chance of the nuts coming loose and the chain adjuster cap being lost on a ride).
Well been out of it for awhile with all this snow during this long winter. Summer if around the corner and I have been working on the grom. Finally got my yosh pipe and installed. Thanks Hard Racing for the quick install vid. Took me all of 20 minutes. Thanks to MNNTHBX oversized bar mounts. Not sure if people have mentioned them but Driven bar end mirrors look awesome and should be a nice finish to my Pro Taper bars.
Sent from my SPH-L710 using HondaGrom.net mobile app
1 - 15 of 15 Posts
