21 - 40 of 112 Posts
Yes it bolts down just fine. I had the same thing on the Takegawa 4 valve head using the Koso manifold, if you take the manifold off you'll see that the gasket hole is a little bigger than the one on the testa del cilindro (see how good my italian is? :joyous:). It's not a big deal, just not ideal. That's why I was wondering if the Takegawa manifold would fit the Koso throttle body.
Looking at the pics you seem to have the nice bracket hanging down from the frame, why didn't you bolt the cooler to it?
Discussion Starter #23
Takegawa bracket holes dont fix kitaco Cooler anyway i removed It.
Inviato dal mio WAS-LX1A utilizzando Tapatalk
Discussion Starter #24
rode in finished
clutch definitively slips
when i wot for first time, both lower valve cover bolts untightened, oil on header, blue smoke etc. fortunately i rode with a friend that warned me...
next week, clutch inspection and bolts re-tightenig plus loctite
Discussion Starter #25 (Edited)
Oook folks, It was the cable too tight
@the end
rode in finished
- oil screen had slightly traces of liquid gasket, a small piece of paper gasket
intake valve was out of tolerance (>0.15) -fixed-
now it does a better noise
it still drip oil from exhaust valve cap & stator
for the rest
it's an awersome upgrade, I'm very very happy :crazy:
i've just ordered pirelli diablo rosso tyres
Discussion Starter #26
It keeps spraying oil in clutch cover. I think It comes from oil filter cap... Devastating... Plus It spits drops also off the oil catch can hose. A little bit... Too much power ps i ve just rode in local highway ring, what a blast
you look to have a high amount of crankcase pressure thus causing all of the oil leaks. are you only using the stock vent with the catch can?
Discussion Starter #28
i'm using the kitaco hoses included in the can kit
kitaco oil cap has no gasket, it's pure aluminium so.... i will try to recycle the stock oil cap gasket
Discussion Starter #29
today i transplanted the oil stick gasket to the kitaco can plug. maybe i'll change also the bottom oil plug's gaskets,tensioner one drips
ah the clutch slipping was
clutch cable too tight :icon_rendeer:
Discussion Starter #32
Clutch slips in 2nd and 3rd gear powershift.....
and here's first video of the year :furious:
yep they're seventeen
Discussion Starter #33
1500 kms
bad news... clutch start slipping in any gear up to 4000 rpm.... before install new ebc discs and kitaco springs i will try to find another axle bolt... mine is half stripped, new parts are crazy different and I do not want to buy the honda tool.... so i want a hex bolt
ah, today i hit 105° c oil temp... no good
plus lower cooler's row smashes against front mudguard, they're both ruined
right fairing has a 5 cm crack that start from takegawa support bar. more or less will not last...
Discussion Starter #34
I swapped springs,same clutch discs.. It grips better but in 3rd Gear when torque peaks... Slip a bit. F***! I installed a hex nut in the clutch axle. way better to tighten
Discussion Starter #36
i registered clutch cable and seems ok. I can feel bike's fully pushing now
Discussion Starter #38
Today. Rip ohlins. I'm literally speechless, except for curses.
Discussion Starter #40 (Edited)
2000 km. from usa. already sat for my weight. i can't figure what failed
but i noticed a few drips during the last months... anyway.... i hope it's fixable !
