I installed the TB cam on my 2015 OG a couple weeks ago and at high RPMs the motor don't sound right to me.. Valves making a slight noise as the RPMs increase. Not noticeable at idle.
At first I went with the recommended I.004 & E.007 valve clearance.. That didn't sound right so I called Hard Racing and they said to try I.004 & E.006.
This sounded better but I can still hear the cam/valves tapping at high RPMs... Its like I can hear the cam spinning and hitting the rockers... Has anyone else experienced this? I have checked the clearances after a few days of riding and they have not changed..
What valve clearance settings have worked for you guys?
Also do I need to (or should I) get stiffer valve springs to accommodate the steeper cam slope?
Chimera Intake
M4 Exhaust
TB Cam
PCV
Stock piston
5,000 miles on the motor.
Chimera Intake
M4 Exhaust
TB Cam
PCV
Stock piston
