1 - 4 of 4 Posts
In your opinion would setting the Takegawa speedo to non-ABS solve the ABS light problem on a 14 tooth sprocket set-up?
I don't have ABS and didn't know there was a problem with the 14T setup with ABS bikes. My guess is that it would fix it, one of either two ways: When I first setup the speedometer, the ABS light was on (and I don't have ABS) - when i got to the ABS selection and turned it off, the light went off. I would assume if you did this, your ABS may no longer work though. The other way that may actually fix the issue altogether is by adjusting the tire diameter selection screen (probably about 94% in your case) which hopefully would let the ECU think that everything is the way it's supposed to be and not throw the light.
1 - 4 of 4 Posts
