1 - 5 of 5 Posts
Hi All,
There wasn't a thread here with the same setup with Temp info. So I thought I should start one to share my experience with it.
Temperatures for Day time where I'm at is between 30C (86F) to 33C (91F).
Stock Temp reading going at 80-90+km/hr for 15mins:
Temp reading on stock cylinder and piston (running on unleaded 95), without oil cooler was between 95C (203F) to 110C (230F).
Takegawa Hyper S Stage 181cc Temp reading - 70-80+km/hr:
Temp reading on BBK 181cc with Cam (running on unleaded 98), without oil cooler was also between 95C (203F) to 110C (230F).
Takegawa Hyper S Stage 181cc BBK with Takegawa Compact cool 4fin oil cooler Temp reading - 70-80+km/hr:
88C (190F) to 98C (208F).
Bear in mind I've not tested WOT as I'm still running in (a.k.a. break in)
So there you have it, the oil cooler definitely works.
Will report temp readings after engine run-in has completed.
Temp taken using the OPMID gauge (same as the one Hardracing has for sale on their website).
Hope the above helps.
Current setup:
Takegawa Hyper S Stage 181cc BBK - SP TAKEGAWA : HYPER S Stage Big Bore Kit 181cc [01-05-0306]
Takegawa Sports cam
Takegawa Fi Con 2 (MAP `E', '7' Setting) - English instructions can be found here: http://www.hondagrom.net/forums/13-grom-performance/4858-takagawa-fi-con-2-a-5.html - posted by YYZGROM , alternatively you may email Takegawa and they will email you the exact same copy in English
Takegawa Compact Cooler 4 fin - SP TAKEGAWA : Compact Cool Kit (4-FIN/Slim Line) [07-07-0180]
Yoshimura R77s Slip on muffler - Yoshimura product site : GROM/MSX125?13? - SLIP-ON R-77S CARBON END
Stock exhaust manifold
DNA Drop in Air Filter - New DNA High Performance Air Filter P-H1N13-01 for the HONDA MSX 125 2013 | DNA Filters Ltd.
Skyrich Lithium Ion battery
NGK CR8E
Motul 300v 10W40
Shell 98 Unleaded petrol
OPMID Volt Meter & Temp Gauge - HARD RACING PERFORMANCE / HARD CORE SPORTS SHOPPING CART - Engine/Head Temperature Gauge w/ Voltmeter (Plug-n-Play)
20140828_153923.jpg 20140828_154229.jpg 1487965_750524308339277_1084035339580158315_o.jpg 10479658_750524398339268_3946187372298130329_o.jpg 1500825_750524515005923_6416538669727077271_o.jpg 10658931_750524275005947_2583928692091848180_o.jpg 10428193_750524445005930_902301065962243387_o.jpg 10631312_750524598339248_2878398827927912422_o.jpg 1492362_750540875004287_1292199581095551886_o.jpg
thanks for your report and feedback on real world riding and testing, yes I'm also getting the Temp/voltage meter that HRD sells just to monitor my head temp on the BrianS 170cc BBK and his Port/Polish/duel valve/bigger valve head that he sells.
How is everything running? any updates? also did you reinstall the decompression device on the takegawa cam?
decompression device wasn't installed on the takegawa cam. no issues with cranking at cold. However, battery has been upgraded, so i guess that helped.
Been riding around, WoT for about 5-10secs, temp shot up to 102degrees Celsius.
80-100km/hr for 10-20mins, temp reading's between 93-100degrees Celsius.
Have about 1200km on the 181BBK so far.
Glad to see everything is running good
1 - 5 of 5 Posts
