1 - 20 of 28 Posts
The Swingarm shaft wasn’t coming out, so I got a screwdriver... only thing big enough was that philips head, and I tried pushing the shaft out... it didn’t come out, but the screwdriver actually got stuck. I tried so hard to get it out, it just won’t budge.
Now for the axle, it won’t move at all. In or out, clockwise or counter. I used WD40, then got a hammer and tried to hammer it in with full force, no movement. I even got an impact and tried so hard to get it to move, not a single mm moved.
I’m thinking either the shaft is bent, or it’s getting stuck. I kind of feel like the screwdriver got stuck in the frame or something, and that’s stopping the shaft to come out. Again, I went full force with a hammer and tried to push the shaft back in, but it just won’t work.
I then took off the shock and put the bike on the stand (pictured) and the Swingarm was moving up and down, but it wasn’t wobbling and the shaft still didn’t move even with the impact.
What am I looking at here? What about the screwdriver? How will I get that out?
A few people gave me some tips. One said to put a ladder over the grom, get some straps, take off the shock, and raise the rear of the bike. Another said to tilt the bike and torch the bolt, then throw Ice Cold water on it (he said it'll shrink it). What do you guys say to do? I have a build to take care of and something small like that is stopping me from doing so. Please HELP. Thanks
Why is the chain still on the bike? It the rear wheel on as well? If so, you're adding pressure to the pivot that's working against you. Get all of that stuff gone, remove the screwdriver, and use the rearset as a slap hammer, while the swingarm is held in alignment. This is all super basic and fundamental mechanical stuff. Avoid the "get a bigger hammer" mindset. Moving forward, I'd put more emphasis on cleaning and maintenance. Nasty parts generally come apart nasty.
Discussion Starter #6
yeah the bike is getting fully disassembled anyways for cleaning + maintenance, so I'll do that too. Yeah I got a new chain+sprockets sitting in the garage.
I think I'll take the shock off again. Do you suggest putting the bike on a lift stand, or would you do the ladder strap method?
Discussion Starter #8
I'd probably set it on the kickstand while I was trying to get the screwdriver out.
I tried it all (aside from the ladder strap thing). I did it with the shock on and off, on the lift stand and on the kickstand... I'll take off the wheel and the chain again, as well as the shock again. Finally I'll lift the rear with straps under a ladder. Hopefully that'll help (don't know how it'll help, but I'm down to do anything). If that doesn't work, I'll try the heat + water method, and if THAT doesn't work, it's time to go to the dealership :(
From the picture it looks like there is a MX type stand that the bike is on. I'd suggest that its not holding the bike correctly and there is pressure on the swingarm causing misalignment. The bike needs to be held securely and safely, that does not include it swinging from an A ladder and some straps.
I'm going to presume that you're disassembling the rear end. I've done this and had problems. I had a seized adjuster and attempted to remove the rear wheel in order to clean and reassemble at which point the rear axle seized as well. To solve this I took the chain off, if you are replacing this anyway loosen the front sprocket nut/ retainer first with the chain on as that makes it easier then remove the chain at the split link. Next is the swingarm, lift the bike taking pressure off of the swing arm as this is coming out. You've got the right peg off and are halfway off with the left so that's progress but taking the shock out or at least removing the link between it and the arm will help. Its now going to be a case of realigning the arm and shaft. Take that screwdriver out first. A little lifting and gentle shaking of arm should free the screwdriver, hopefully that will also allow the pivot to be released as well. If not a little bit of manipulation with the left peg as a slide hammer might help, or applying heat to the arm or pivot point could help. Heating the bolt then throwing cold water on it will not fix the problem. That should get the arm off for you.
Now I could be wrong but it looks like you might still have the rear brake attached. I would recommend looking at that even possibly before removing the arm. I think that's an original Grom you have there so the rear reservoir is behind the fairing and the master cylinder is on the back of the peg. There is also a pipe guide on the arm that might not want to come out easily. Take as much off from the brake system as you can as it will make the next steps easier as you need to remove the rear axle.
I did that by having removed the arm from the bike and the brake system from the arm lifting the arm on a couple of blocks of wood persuading the axle to move using a course hammer and a drift. And by drift I don't mean a screwdriver. A drift is something similar in diameter to the axle, but be aware pounding on the axle can mushroom the head. Now there is of course a risk that this has already happened to either the axle or the shaft so that something to be mindful of. New shafts and bearings will be required if that has happened.
With the axle out the wheel is free and everything is dissembled. Budget for new bearings, bushes, axle, and pivot. I did, plus I added a new arm, different wheels, shock, pegs, and barking system parts.
For anything you'll do on the bike in the future, do yourself and your bike a favour, download the service manual and READ IT!
This entire procedure for example is explained step by step, it even has pictures.
It will tell you if you need any special tools, what needs to be greased, oiled, replaced or checked, torque values, which way things need to be disassembled or assembled, etc...
It is the best and most complete ressource if you need to work on the bike.
And like MNNTHBX suggested keep it clean. Try to work in a clean environment. Clean the bike or parts before disassembly. Keep the parts stored cleanly and organised.
Might seem like extra work but it will save you time and money (yes, really!) on the longer run. Plus it's just a much more pleasant way to work.
Ending up with a greasy pile of parts on a dirty floor is very very very wrong!
And last thing, tools. Get the right tools, it will make everything much easier and you won't damage anything. It will cost some money but again you'll save time AND money on the longer run. If you need impact guns and hammers you're probably doing something wrong. Seeing you want to take the bike appart I'd at least invest in a torque wrench.
Discussion Starter #13
Yeah I took off the wheel, the chain, and all that. The brake system is still on. I did remove the MX stand, and put it on the ladder haha
Discussion Starter #14
I have a torque wrench too. I ended up using those things because the shaft just won't budge.
Discussion Starter #17
you need to get that screwdriver out of there first. sounds like its wedged between the swingarm bolt and the frame stopping all forward progress.
Yeah I think that's why. How would I get it off? It's a philips head. The handle is plastic so I'd hate to have it snap off the metal (I don't care about the screwdriver, it'll be a pain to get just the rod off)
Discussion Starter #18
Did all of that... still won't budge haha
You probably need two or three people to move parts around while trying to pull out the screwdriver. I would have one person move the swing arm up and down while someone else holds the bike (keep from swinging), and another person to pull on the screwdriver. You might need to vice grip the screwdriver to have leverage on it. At this point, a "bigger hammer" might be needed to get the screwdriver out.
Discussion Starter #20
I'm fine with ordering a new shaft and all that. I took off the chain, removed the shock from the swingarm, and even removed the rear wheel. It is now on the ladder-strap "stand". I don't have any other stands lol. I lifted the swingarm, pushing it up and down, but still nothing. I did more than lifting and shaking gently lol, I tried moving it with full force. Applying heat to the axle?
1 - 20 of 28 Posts
