1 - 19 of 19 Posts
Has anyone mounted there plate to the swing arm vertically? Pics would be great. I know it illegal but cops don't care around me as I have it on all my other bikes. Thanks.
Discussion Starter · #7 ·
I built one for mine. It's not letting me post a picture but there is one on my built thread
looks good, did u make it or buy it??
Used my Mojo Ruckus plate mount. Close to the chain, but works good.
Sent from cell. SPARKLE.motion
any pics of it, id like to buy one rather than make one, but i could make one if i needed too. thanks
Discussion Starter · #10 ·
I did make mine because I couldn't find anything I liked
if you can post some pics of the mount sideways. I'm interested in how you built yours..thanks
funny that you asked this question. I recently finished my Composimo stretch and lowering of 2" in the front, and 6" in the back... I have the composimo tiddy tail too, you cant run the plate on there with the 6" rear lowering... So I was searching for something that would work... I'm going to run this on the right hand side rear swingarm bolt. I will probably make a new top plate to hold the stock plate light. just have to extend the wiring, and run it along the frame. im also going to sleeve the wiring
Motorcycle Vertical Side Axle or Shock Mount License Plate Bracket Naked Steel | eBay
the braiding will be similar to this.
3 8 in Braided Techflex Expandable Wire Sleeving Loom 10 Feet Wiring Harness F6 | eBay
Discussion Starter · #13 ·
Discussion Starter · #15 ·
No mod, just choose the plate mount holes that work for you. ;)
what holes does it mount on to the swing arm…if you could get me a side pic and just text it to me that would be awesome, i can pm u my number or email, thanks
Hey heads up the little tab that that the rear hugger screws it by the axle is weak. Mine was supported off of the axle adjusting nut and that one and that tab broke off after about 1500 to 2000 ish you might want to keep an eye on it I will be redesigning my bracket to be alittle stronger and will be welding a larger bracket to hold everything in place
Which plate light wires hook with the black and white tag bolt wires? Factory tag wires to two bolt tag lights?
Sent from my iPad using HondaGrom.net mobile app
1 - 19 of 19 Posts
