1 - 5 of 5 Posts
Read Only
Just got a brand new 2015 Grom! i was wondering if anyone had suggestions for how to go about installing a switch to allow all lights to be shut off(headlight, tail light,blinkers etc). I think this could be useful at times...:big smile::big smile::wink::wink:
To do it properly and cheaply, Multiple switches.
Properly (and slightly more expensive), 1 switch and multiple relays.
cheap and improper, 1 switch, use it to open circuit the ground on all of the lights.
(no idea if this will work, but just taking a guess, maybe ill try when im home tonight)
To do it the improper way... Under the seat, there should be 4 green wires grounded to the frame (right behind the tank). Determine which of these wires is the ground for all the lights, horn, and kickstand switch (you may need to bypass the kickstand switch). Your switch should go between that wire and where it used to be.
The improper way should work. Not all that improper to be honest. Cutting the ground has always been a reliable tried and true method.
1 - 5 of 5 Posts
