1 - 9 of 9 Posts
I bought my grom used and when looking to remove the fairings today 3 of the phillips head screws securing the fairings are stripped horribly. Does anyone have any recommendations on how to get them out? I have tried an impact screw driver and a grip it bit but they are NOT budging. Can I access them internally? Any help is GREATLY appreciated as I need to get my ECU out to send to DHM.
Thanks!
Which screws are you speaking about? location?
The screws without are the four that grip the fairing, the ones that have the indicator, the screw can eat the head and try to screw it in and remove it from behind, I do not know if I explain myself
The pointy end of the rear cowl and the rear of the side fairing screws can be seen when you take off the seat, at least you can soak the screws with rust penetrate from that view, I suppose you might get some long needle nose pliers on them.
1 - 9 of 9 Posts
