I am sure we will see all different versions of stock exhaust modifications. This is what I came up with. It sounds great, louder but not too loud and no popping at all on decel while in gear. I'll post pics after pc.
Needed to rid the tail of that big stock can...
First we dissected it:
After some P.I.T.A. internal work, it was neatly welded back together.
A quick mock-up of the header pipe, connector piece, and can.
Once fitment was perfect, all final welding was done. The stock hanger bracket was welded back into place onto the can. It sounds nice, and seems to flow much better. It'll be coated soon! :hondalogo:
After installing a Bazzaz ZFi I had to weld in a bung. Figured I'd add that to this thread.
First a little hole sawing.
Test fit & grind. Then repeat.
A little welding.
Then the charcoal canister was removed to make room for the Bazzaz.
Wide band in its final resting place. Now, let's see what the Bazzaz is all about.:happy10:
A little welding.
