1 - 20 of 22 Posts
2020 White Honda Grom
Hi guys and gals, I get a kick out of checking out what everyone's done to their Groms so I wanted to start a thread on my new Grom as well!
Here it is with zero miles on it when I picked it up:
88513
And after a 31 mile ride home here it is at its new home!
88514
As I was checking everything out I noticed the license plate light just didn't seem right, it was really loose. I hopped onto hondagrom.net and searched around and found this was normal apparently, but I did find a thread where someone was able to figure out how to tighten it: Love my Grom....but a few minor things I wish to change:
I can't believe this would be this floppy to protect the bulb filament from vibration but who knows, I put an LED bulb in there anyway so it doesn't matter. To fix this you'll need to put a couple washers around collars #4 in the part diagram below, or you could grind off some of the length.
88515
Put it all back together and everything snugs up like you would expect it to:
88516
More to come,
Cheers!
Stewart
Reactions: Ninelives17
That is a great way to fix the tail light. If I ever have mine apart I may do that. Looks solid.
I ended up slipping an extra gasket (#6) in between the parts. It took 95% of the wobble out of it. They cost less than a $1.50. I didn’t have to remove anything. Just had to modify the gasket by cutting the center of it out. I bought a couple of them. Took a couple of tries to get it right. Used a feeler gauge to help work it into place.
88519
Discussion Starter · #3 · (Edited)
Upgrayedd (haha good movie btw) that looks good too, for sure more than one way to fix that light.
I had heard how uncomfortable the stock seat is and by the time I got home I was in agreement, it's hard and the shape of the seat doesn't let you move around. Below is the replacement, unfortunately I haven't been able to ride it yet with the new seat but just sitting on it, it doesn't feel much softer. We'll see after I get a few miles on it.
88524
And the reason I haven't ridden it again since I brought it home is... I haven't had a bike with a chain drive for a while so I was reading other peoples experience with the Grom's chain. Some people said it comes pretty dry from the dealer and others said it came adjusted pretty tight. I looked at my chain a little closer and decided to lube and adjust it.
After I finished that I was wiping off a little excess lube and took the plastic chain guard thing off which kinda fits on top of the swing arm to get better access, the two rear screws come out fine but the last one which is more toward the front on the left side feels like it's cross threaded as I'm unscrewing it :(
Looking at the threads yeah they are messed up, so naturally I take one of the other ones and screw it in... it goes in fine for a couple of turns and then I can feel resistance. I take that one back out and now two of the three screws are messed up.
88525
I think a weld splatter got in there or something, you could see the threads and they were not crossed. I chased the threads with my M6x1.0 tap and test fitted the last good screw. Whew, all is good, it went in and out fine.
88526
But now I'm waiting for the new screws to get here from partzilla so I can put that stupid chain guard back on so I can ride it again! Oh well. While I was ordering stuff I ordered a few of the spinner gaskets and clutch side cover gaskets so I'll have them later when I'm ready to do that maintenance.
I’m not sure if I would like a different seat or not. I’m pretty happy with the stock seat. I’m a cyclist, so I’m used to sitting for long hours on a very minimal bicycle saddle. I rode for about 13 years on a saddle that was nothing more than a $600 piece of carbon fiber! No padding. No cover. Just a 64 gram piece of carbon fiber...lol. So the Grom seat feels like a sofa by comparison! Maybe I’ll try another seat someday to see if I’m missing out.
Yeah, my chain was too tight and pretty dry. My stock swingarm had splatter all over it in some areas. I’ve since replaced it with an aluminum swingarm. I keep 3 each of those clutch cover and stator cover gaskets on hand. Not a bad idea to have extra gaskets.
Reactions: Stew
I had a little time this morning before I have to work so I got my rim tape put on. I bought the customtaylor33 in lime green and the color is a great match.
88598
The tape is a metallic type tape, like the yearly sticker you put on your car or motorcycle license plate, looks like pretty decent stuff. I overlapped in the direction of wheel rotation so if anything snagged it it wouldn't catch it and try to peel it off. To do this all the way around you have to leave a little bit open on the first piece so you can tuck in the last piece.
88599
And here it is finished. It's a little trickier than I thought keeping it even all the way around, when you spin the wheels the tape wobbles a little, I'm going to try to not let my OCD obsess over it haha.
88600
More to come.
Stewart
Discussion Starter · #7 ·
Got the new shorty levers put on today and the replacement chain guard fender screws should be in tomorrow so I can actually start riding this thing! It's been sitting in the garage since I rode it home from the dealer on Oct 6th, plus the weather is supposed to be decent, I can't wait!
New goodies, black shorty levers with green adjuster:
88621
Old:
88622
New:
88623
My parts finally came today... I got three clutch side case gaskets, three spinner gaskets and two crush washers for future maintenance, the three chain guard screws and a trim piece for the Goldwing. Got the screws put in and went for a quick ride, got a good pic here.
88645
Excellent start to your build! What kinda things do you plan on doing? Stunting? Track? Canyon carver?
Discussion Starter · #10 ·
It’ll probably see mostly urban duty, commuting, errands and stuff… There’s a guy with a Grom at my work and another person that's getting one of the new Trail 125’s when they get here so maybe an occasional miniMOTO group ride as well. We got another guy with a Ruckus but it would be harder to include him because of the lower speed, we’re working on him to upgrade to a Grom :)
Nice, that's what my build was (is I guess, it's never done). Made it a commuter king, urban runabout with upgrades to keep reliability. I have a build thread here as well, but I think my build was made significantly better with the following:
Suspension upgrades
Stainless Steel braided brake lines
Clutch cover that removes the spinner and adds an oil filter.
Stiffer clutch springs and clutch plate.
Shift lever that's not connected to the foot peg.
I did many more besides, and still find things to do, but these upgrades are worth every penny.
Discussion Starter · #13 ·
Thank you, I haven’t got to ride it hardly at all the last several weeks, like the rain gods knew someone out there has a new toy so let’s make sure the weather is really cruddy all the sudden.
I did do the first oil change already. I’ve always done early oil changes on new engines (especially ones with out filters) to flush out any big wear particles and leftover machining bits, and replaced the drain plug with a magnetic plug.
Discussion Starter · #14 ·
With the weather turning nicer here in the greater Seattle area I've finally been able to ride the Grom more! One longer ride I recently did (for those who know the area) is from Smokey Point down to Maple valley, about 65 miles one way, to visit the old man. On the way there I took secondary highways but on the way home I hopped on 405 in Renton up to I-5 the rest of the way home. I don't know if I got lucky with this Grom or what but on level ground moving with traffic I could maintain 64-65 mph just fine. Totally stock.
At any rate, after commuting to work today (again on I-5 through Everett) I now have 502 miles and just got done changing the oil for the second time. I'll do a third at 1,000 miles and then longer intervals after that.
After the first oil change I put a magnetic drain plug in, here is what it looked like from mile 150 to 500:
90128
Also I've got some new goodies to put on it, they're not all here yet but here is a sneak peek:
90129
When the rest of the parts get here and everything's on there will more pictures to come!
Discussion Starter · #16 ·
the best thing about the seat is having more freedom in your seating position since you’re not locked into one spot like the OEM seat but I do wish the padding was softer. Also it doesn’t fit quite as securely as the original seat, overall not bad for the price I suppose.
I’m tempted to get a Corbin but I’m having a hard time talking myself into it without knowing for sure if it’d be that much more comfortable. It would be nice to borrow one for short ride before dropping that kind of coin.
2014 Red Grom
Look into the AirHawk seat cushions and the cheaper clones. So many people were praising them, even on their custom seats. I just bought a clone for $22 on Amazon during a flash sale. I'll be playing around with the air pressure to get the most comfort this weekend. I have my bike up on stands adding a few upgrades and can't test it out yet.
Discussion Starter · #20 ·
Yep that is the exact one!
Reactions: Chillis
1 - 20 of 22 Posts
