1 - 20 of 57 Posts
I figured I'd post a build because I'm seeing a couple people interested in my findings and I want to provide as much information regarding the Takegawa 143 as I can. Also, I need help from you guys. This is uncharted territory for me and while I've read a ton of posts about BBKs and the like, there's still a TON I'm unsure of. If you see something I post and you're thinking it doesn't sound correct please let me know. Also the electronics side of things is a weak point for me so please explain things like I'm 5.
So I installed the Takegawa 143 along with the Takegawa S stage cam. The hardest part was the piston rings. I had to re-do them three times because something stupid would happen and mess it up. For example I had the piston on, clips in and I was pushing the cylinder on. Well the crank decided to move and the piston pulled out of the cylinder... Then I forgot to cover the hole into the crank case and a c clip flew off into what I though was the crank case. I was so defeated when that happened. Luckily it was in that slot where the cam chain goes and it's a magnetic material so all was good.
I have a little over 20 miles on the 143 kit and 2 heat cycles. Valve clearances look good, no leaks, spark plug has no oil on it and it was mostly a light brown color. All I'm running is an EFIE set to 260 whatever it is. Volts? I just followed the forum post instructions and change the setting on my meter until I see the hundreds. I'm an accountant not an electrician damn it.
I'm using an Innovate MTX-L Plus to monitor the AFR and so far it idles around 13.3 +-.2. I've been staying around 5,500rpm for the break in and the afr stays around 13.0. I did have a weird anomaly yesterday were I came to a stop light and the afr kept going down. The temp was I think around 170F. The afr got down to 10.9 and the idle was a bit low. Throttle response was normal and when I came to the next stop it was fine. For the rest of the ride I had no problems. I let it idle for about 10 minutes at home blipping the throttle every once in a while and it would always settle in the low 13s.
I wish I had a data logger for the afr. If you guys know of an inexpensive system that would work with my gauge let me know. From what I can tell, if I were to go more with Innovate, I would need their tach gauge and the logger system.
In terms of heat I'm using the Opmid gauge. Riding around keeping around 5500rpm the temp was as if it were stock. It only broke 200 when I let it idle for 10 minutes at home. It hit a max temp of 225 and I decided to ride it around the block to see how fast the temp would drop and it went down to 215 relatively quick. I'm confident it would have continued to go down the longer I rode. I'm 99% sure an oil cooler isn't necessary with the 143 kit.
Once the break in is done I'll get a better idea of WOT temps and afr and regular riding data as well. The pcx 150 injector was delivered today so I'll slap that on, reset the ecu, check the bolts and go for a ride. I also want to check and mark the cam sprocket bolt to see if it moves over time. I remember reading a post that it likes to work it's way out.
I'll post some pics of everything in a bit. Just wanted to write down what I've seen so far and some thoughts.
Here's the mods I have:
Takegawa 143 kit
Takegawa S Stage cam
PCX 150 fuel injector
Kitaco clutch cover
Takegawa oil pump with SUP catch tube
SMR 6 disc clutch with 60% springs
Koso clutch plate
Some aftermarket intake (previous owner put it on. might be the black chimera one)
Ebay full exhaust with a bung welded on
Innovate MTX-L Plug AFR gauge
Opmid temp gauge
OTB chain adjusters w/ spools
Seat Concepts seat
14/36 sprockets
Pirelli SL26 tires
A bunch of other cosmetic mods (I'll post pics)
Discussion Starter #2 (Edited)
Pictures!
Here's an overall picture of my bike. Taiwan head light with LED H4 40W Turbo lights from ebay, amazon z125 style mirrors, gold ebay levers and bar ends, and progrip grips.
Ebay header. Bung was welded on by a local shop. It can fit any can that has a 54mm opening. I chose a dual can. Some older gentleman said the exhaust reminds him of his old scrambler.
Innovate afr gauge and Opmid gauge. Gauge mount 3d printed. Got the design files from turp (thanks turp) and modified it a little so I didn't have to rewire it. Also the handlebars are for a drz. Previous owner put them on.
Seat concepts seat. Everyone said it was the best mod they put on their grom and I was like ya ok sure. I'm sorry I doubted you.
YSS rear shock. Previous owner put it on. I have nothing to compare it to, but I have no complaints
OTB chain adjusters. Also 36T sprocket the previous owner put on. He didn't really have a color scheme for the bike, it was just a bunch of neon colored parts all over. Except the rims, which I think he just spray painted. I'm going for a gold and black scheme.
TB aluminum shifter with Hard Racing shift support bracket
I'm only including this pic because i want to show you how faded these Yoshi plugs are. Previous owner put them on. They're fading to pink. I had a guy on a CB360 comment how he liked the color scheme I was going for with the black and gold and pink. It took me a second to understand what the pink was.
Wibbly don't look. I'll clean up the wiring in the future I promise.
EFIE and afr gauge wiring. I used some velcro to keep the EFIE mounted down, but still accessible. Also used bullet connectors so if the EFIE craps out I can bypass it and run it like normal.
Ebay levers and bar ends. I've never had high end levers on any of my bikes. I just couldn't justify them. I'm happy with the ones I have.
I like how your grill matches your car! LOL
That seriously never dawned on me lol.
Do you mean like the stock shifter? The previous owner put some neon green ebay shifter on and told me a horror story of when one of his buddies still had the linkage type and laid down his own grom and something broke. Apart from the shifter everything was fine, but how the shifter is connected it broke something on his rearset too? I never looked into the linkage type. The TB is nice. There's no play in it and I have no problems finding neutral.
Just for fun I'm starting a design for a shifter to 3d print. I already made a test fairing support bar that is super light and surprisingly strong. I just have to make it 3/4 of an inch longer and it'll be perfect
Discussion Starter #6
Just got the pcx 150 injector and it is adorable! I didn't know it was so small (that's what she said)
Discussion Starter #7 (Edited)
Ran the pcx150 with the efie today and played around with quick takeoffs, wot in 4th, and some other throttle position stuff. Reset the ecu and throttle position sensor. On initial start it ran very rich. To the point where it died twice. The third time I gave it a bit of throttle to keep it going and let it go after a few seconds. It started out at 11.0 afr and gradually climbed to 14.0 at idle which was disappointing. I'm not sure if it should have been disappointing to be honest. I read that the 150 injector i got (2015+ year model) was giving people trouble with erratic afrs and I thought that was going to be the case.
Went for a quick ride around the block and it slowly got better. Idle was all over the place but throughout the rpms it was in the mid 13s.
After 20 miles doing mostly indicated 40 in 4th gear at 5500rpms it stuck going between 12.8 and 13.0. Idle was still all over the place. There were a few instances where it would drop to 10.7 then jump back up to 12.5 and it would keep doing that until I started moving again. Sometimes it would be in the mid 12s and sometimes it would be in the low 13s. Throughout the rpms and throttle % it would ultimately end up at 13.0 which I think is fine. The efie was set to 250 and maybe if it was at 260 it would be even better. At the end of my ride it idled at 13.2 +-.2
Before I adjust the efie, I'll put more miles on it and allow the ecu to adjust. I think I read somewhere it takes like 100 miles for it to fully adjust? I could be making that up.
Temps are still good. With more "spirited" riding it hovered around 210 and at stop lights would go to the upper teens. Highest I let it go was 235 which was when I sat for a little watching the idle afr after some harder riding. Even then it didnt really want to go any higher and quickly went down once I got moving again.
You can always point a GoPro at your AFR gauge, bonus if it can capture your RPM and throttle position as well.
Hopefully your idle AFR will smooth out as you let the ECU learn more. However, I had a problem when I was using the Finbro ECU and PCX150 Injector. My idle would always be in the 10's. You could smell the unburnt gasoline. But as soon as I cracked the throttle open, AFR would be in the "normal" range (12.5-14.0).
You might not even need the PCX150 injector if your bike was running fine with the stock one.
Discussion Starter #9
That's a good idea. I'll have to find my gopro.
I'm thinking if this injector doesn't work out I'll try the other pcx150 injector. If that doesn't work then I'll either just go stock or try some others just to see. I'll just have a collection of fuel injectors.
The TB shifter bolts directly to the shift shaft which may be bad for your engine in the event of an accident. The linkage absorbs impacts and protects that shift shaft.
The linkage also provides some added leverage for ease of shifting.
Discussion Starter #11
I just read through a post about making a new linkage and it'll probably be something I do once I get the fueling figured out. I'll need to buy the stock shifter too
Your bike looks great and I like your approach of trying things out to see how they work. How does the 143 compare to the 125?
Following your build with interest! :)
Discussion Starter #13 (Edited)
Thanks!
You learn a lot through trial and error.
The 143 is what I was looking for. Riding around town I'm not thinking "I wish I had just a little more power." I'm 5 10 at 225lbs and 4th gear still pulls up a medium sloped hill with the 14/36 sprockets. It's kinda a weird feeling when you're so used to having to shift down. I'm probably going to have to switch the sprockets up a bit if I want to do some highway riding. Maybe a 15 front will be enough, but I'll cross that bridge once I get to it.
I've been mostly cruising at 5500rpm in 4th gear at a little over 40mph indicated. If it stays nice outside today I'll find my gopro and record my rpm, temp, afr, and if I can get it in the shot my gps speed.
Also Tooter I'll get a fuel economy number as well once I get the fueling under control.
Lord Squirrel,
Thanks for starting this build thread. I am also interested in many of your results and modifications.
I look forward to more of your reports.
Paul
Discussion Starter #15 (Edited)
Short but hard riding today. I threw in a new spark plug before I headed out.
Initial start looked good. No flooding this time.
I rode it like I stole it today and it responded well. AFR were hovering around 12.8 or 12.9 during cruising. Throughout the rpms it would stay around that area as well.
I took it on the highway and I love it. I only did about 2 miles to one exit then 2 miles back. The highways around here are 60mph speed limit but people usually do 70ish. I kept up with traffic easily and actually passed people with no tuck. Just normal seating position. Indicated was 68 and I didn't need wot to keep that speed. Afr was 12.5 for when I was normal cruising. WOT on the initial 2 miles stayed at 11.2. On the way back it was 12.0 but one way is slightly up hill and the other is of course the opposite.
Idle is getting better slowly. Still some instances where it wants to drop down it about 10.7ish. Mostly it stays in the upper 12s or around 13.0.
Temp on the highway got to 235. When I was stopped at a red light right after I got off it creeped up to 245. Once I started moving again it went down to 230 and stayed there. It was 90 outside with 70% humidity here.
I pulled the plug once I got back and other than the ground strap being a light brown color throughout, it didn't look like it changed at all.
No gopro today. All my batteries were dead.
Oh and the engine vibrates a lot at these speeds.
lol I hate C clips, those can either magically disappear or spontaneously take off for a flight... and eventually disappear.
Nice wright up!
Discussion Starter #18 (Edited)
Rode to work today which included back roads and 6 miles of highway. AFRs look good. Stayed below or at 13.0 for most of the back roads and in the 12s for the highway. WOT on the highway will drop it down to the 11s, but other than initial acceleration or over taking I didn't need WOT.
Temp stayed at 225 on the highway. When I got off it crept up to 235. I may explore some heat dissipating options just as an experiment. Another thing that's been on my mind is crank case venting. I'm not sure where I want to go with that. Thoughts?
The only problem I have right now is the idle afr. I thought it was getting better, but now it's staying in the 10s more. I'm going to play with the idle screw on the throttle body and see if that helps. The pcx150 injector equivalent on Yuminashi's website says you have to adjust the idle screw if using that injector so maybe that's the fix. I hope so because I'm pretty satisfied with how this combo is working.
Discussion Starter #19
Half day Fridays! Yay!
Took the same way home. Averaged 68 indicated. Got behind a truck and drafted to 72 indicated.
WOT afr was 11.2. Temp stayed under 220 the whole time. Cruising on back roads dropped the temp to under 210. It's mid 70s out.
Idle is definitely staying in the mid 10s. Will work on that and change the oil after lunch. I have 100 miles on the new build. Still very happy.
I bought this too https://theruckshop.com/product/trs-honda-grom-msx125-billet-cnc-cam-cover-made-in-usa/
1 - 20 of 57 Posts
