1 - 12 of 12 Posts
Premium Member
I think its on the counter shaft, there is a plug in the top of the case just above the sprocket. I saw at least three wires there and usually there is only two wires there for the neutral switch. I could be wrong..
Discussion Starter · #4 ·
roger dodger, found it and fixed my issue.
thanks for the quick reply gentlemen.
:happy1::happy1: I'd like to know too.
Discussion Starter · #10 ·
didn't realize there were so many replies to this thread. a friend was testing a rev-limiter delimiter on my bike and i think they had to plug it inline to the 4 plugs location next to the two wire speedo sensor.
there happened to be two 2 wire plugs in that loom and they accidentally plugged them into the wrong female ends, which in turn kept my speedo and odometer from working.
I think the de-limiter was from a Honda PCX, don't know the details on whether it worked or not.
HAS ANYONE TRIED THIS REPLACEMENT GAGE SET WITH WHEEL SPEED SENSOR ?
http://www.drowsports.com/stage6-speedometer/
Stage6 Speedometer
Zoom
[h=1]Stage6 Speedometer[/h]
Be the first to review this product
Share Share on facebook Share on twitter Share on pinterest_share Share on google_plusone_share More Sharing Services
Availability: In stock
$185.99
Stage6 Speedometer with RPM, thermoeter, fuel gauge and Odometer.
*ColorChoose an Option...OrangeWhite
* Required Fields
Add to Cart Qty:
-OR-
$185.99
* Required Fields
Add to Cart Qty:
-OR-
Description
Details
The Stage6 Speedometer measures in at approximately 100mm x 60mm x 20mm and requires a 12V supply from the battery. Revs are picked up inductively while the speed is picked up via a magnet sensor installed at the wheel. Use this to replace your stock speedo for a sleek new digital setup. Available in a variety of colors.
Additional Info
Additional Info
SpecificationsApplications:
  • Two-Stroke Engine
  • Four Stroke Engine
  • Most Scooters
Stage6 Speedometer Features
  • Speedometer 0-360 km/h (or mph)
  • Rev counter up to 20,000 rpm Scalable rpm curve
  • Thermometer 0-250° C (PT-1/8″ sensor)
  • Engine hours meter 0-999.9 h
  • Fuel guage 0-100%
  • Voltmeter 0-18.0 V
  • Odometer
  • Shift light
  • Top speed Read Back
  • Temperature Alarm
  • 7/8" Handlebar Mount
BrandStage6
Zoom
$185.99
* Required Fields
Add to Cart Qty:
-OR-
Related
1 - 12 of 12 Posts
