speed test to day
13209 Views 28 Replies 12 Participants Last post by  gromhawk
hi this is my up date on speed testing . I went out on a 50 mile round trip to day and it was interesting on one down hill run I hit 71mph at 8200rpm just in the red zone not to bad considering my 15 stone and 5.9 height the bike has now done 400 miles... speed as follows 50mph at 6000rpm in top 60mph at just over 7000rpm it holds 50 to 60 on normal flat ish roads and the slowest It went to day was 45mph up a 1 in 10 hill in 3 gear. the bike is also returning about 120mpg not bad mostly flat out . I hope this helps any one who has not got their bike yet I had a smile on my face nearly all day the forks did bottom out on me twice but the roads round me are in very poor condition I do sit a little further back on the bike than normal when flat out and it feels ok . hope this helps ajr uk
1 - 20 of 29 Posts
How high does it rev in neutral? The muffler videos I've watched from the Thai guys it seems to rev to about 9100 in neutral
Thanks, ajr. This is exactly the kind of info all of us who have never ridden one want to know. No vibration or a feeling the engine is about to explode at wide open throttle then? Do you think the MSX125 would let you ride wide open throttle on a carriageway at top speed day in and day out?
I think about 8500rpm would be max for a lighter guy or gal ajr
My idea is to maybe go +1 tooth on the rear to "free up some power" and hope its revs a little easier in 4th, I also plan on going with a 140 rear which will be a bit taller than standard.. Then again I actually need a Grom to try these things on :crazy:
..is it August yet?
hi aj nin it will let you run flat out all the time with no problems but you do get a lot more vibration at the top end rpm I can live with it just i love this little bike the black bird not got a look in since I bought this . I got it to go in the campervan but I can not stop riding it about all over the place its in its element in town it will out accelerate most cars at the lights smiles all the way ajr
hi I am going to keep mine standard for now acceleration is very good from the lights ajr
Thanks for the info AJR.
Sounds like so much fun and 120mpg! That's awesome, just a few more weeks to go...
Heck completely stock it sounds like the Grom with have plenty of speed for my local roads.
+1 and add to that his mention of pulling away from cars at a stop. That just gave me the go-ahead to -1 the rear or +1 the front sprocket for a couple more MPH at the top
Yeah ,I plan on going +1 in the front. Still looking for a company that sells front sprockets for the Grom though.
tyga has some +1 front i believe pal.
This isn't a good idea. The engine is designed to be under load. Redlining your bike in neutral is just silly.
haha I know, I was just curious if the Thai bikes revved higher for whatever reason
Nice they must have just added it, but they don't have a 16t yet.
We didn't put a 16T up on the site yet because, frankly the stock gearing is about all the Grom can pull as it comes from the factory and a 15 is going to be a struggle. Going to a 16 would require a lot more horsepower to get it to work. Not impossible and if there is a demand for 16T sprockets, we will add them. More rear sprockets coming in the next few days. Sprockets - Tyga Performance
The other thing to note is that a bigger front sprocket with the same gearing as one with a smaller front and smaller rear, will mean more power loss so you are better going for small front sprocket and smaller rear.
hi paul , are you finding any particular set up run well ? thanks
Paul, I would guess that with us Grom riders from the states going to big bore kits, you will see a demand for a 16 tooth.
1 - 20 of 29 Posts
