Prices posted below. Shipping included. Insurance extra.
Hindle Header with SC Project Muffler
- $225
Hindle High Mount Header
- $250
New Koso 170 4v BBK with Koso Tensioner
- $800
”New” 28/24 Big valve head with DHM Ti retainers, ported for KOSO throttle body (included), high lift cam and lash caps. Fitted for measurements, not run.
- $600
JC Racing Ported big valve Monkey head 27/22, dual valve springs, includes KOSO Throttle body and Takegawa tapered manifold, high lift 6.1mm lift cam and lash caps.
- $500
KOSO 170 2v BBK
- $225
Ren MW 125 Hi-comp Piston and Jug (400mi refreshed), New gaskets
- $100
10 Hole injector
-$50
Aracer Mini5 for 14-20 Grom or 19-20 Monkey
-$320
Used Takegawa N-20 cam
- $75
Finbro 183 cam 6mm lobe lift on intake (should not bind in stock head)
- $125
Bigass cam 6.1mm lobe lift (fits in Finbro or TB valve heads, binds on stock valves)
- $100
NK Racing Adjustable Cam Gear
- $35
Koso 34mm throttle body
- $90
Takegawa oil catch can for OG grom
- $100
New intake for 34mm throttle body Uni Filter, need your own clamps
- $60
New EBC big rotor
- $140
Ported stock manifold 25mm on head side (matches Finbro) 28mm on throttle side
- $40
Z&Z axle sliders
- $50
MNNTHBX Swingarm Bushings $85
- Tool rental $60 refundable deposit and cost of return shipping
Swing arm with needle bearings vs bushings
- $200
36T aluminum sprocket
- $25
New SF Fuel Filter
- $25
Headstuds
- $25
New Solid Bar mount bushings
- $25
Stock intake manifold
- $25
38mm silicone intake hose for stock throttle
- $20
Takegawa Intake Temp Sensor mounting bracket
- $20
Bracket to mount Setrab 1 Series Cooler to the Kitaco cooler mount
- $20
Cam Tensioner Arm Hard Geared Wheel or Rubber Geared Wheel
- $20
Copper Head Gaskets 58mm (153) 60mm (154) 63mm (181)
- $20 ea
Aracer Speed input wire
- $15
Dual valvespring
- $10
Oil cap vent
- $10
Manifold spacers 25mm
-$10
Magnetic Drain Plug (hits screen, fits stunt oil pumps)
- $10
Baffle
- $10
China phone mount modded to hold afr gauge
- $10
Manifold spacer stock
- $10
Monkey peg springs
- $10
