Hi,
OK - as promised - I got my daughters bike Dyno'd
The bike has around 800mile on it and around 60 miles on the Light Bore Kit
The bike has the following mods
1. Yoshimura RS9 Full Exhaust
2. K&N R1100 Pod filter with air sensor mounted in the end.
3. Yuminashi Light Bore Cylinder and Piston - 150cc
4. Yuminashi Standard Head Race CAM
5. Yuminashi Valve Springs
6. Yuminashi Light Bore Injector
7. Yuminashi Light Bore Controller.
8. Std Gearing
9. Larger Mitchelin Pilot Rear Tyre (140) which has an increased rolling diameter of around 2%.
I have been running the bike for a while with just the Light Bore Kit, Light Bore Injector, Exhaust and Filter. On the weekend I fitted the CAM and Controller.
I am running the standard Throttle Body - with the bigger Injecter.
When I first connected up the Controller I could not get it to run well - rough ticking over etc - hesitant.
So I then fitted the Standard Injector - that was worse - but I forgot to reset the ECU
So I reverted to the Light Bore Injector as a starting point for today.
I went to a Company REPS - near me (25 miles) - weather is awful - so loaded it in the Shogun (Montero for you USA guys)
Here it is with Roy on the Dyno
On the right is the AFR gauge - so you can real time see whats going on.
Then he set it all in motion
Run 1 - Light Bore Injector - No controller
AFR ratio was everywhere - bike made 12.59HP at around 8000 RPM
Run 2 - Connected the Controller
AFR still everywere - too rich and too weak - depending on where we were - Bike Made 12.32 HP at around 8000 RPM again
So I then swapped the Injector to the Standard one
We then did more runs - with the controller maxed out on all settings - we were unable to get the AFR correct - running too weak (different to Snake - no idea why)
No matter the setting it just ran weak. (reset ECU inbetween)
So then refitted the Light Bore Injector
Roy then did around 20 or so runs adjusting the controller - no matter what the setting - he was not able to get an AFR that was good everywhere.
The best results saw 13.07HP at around 8500 RPM
If you look to the graph - different runs - different conditions you see on the bottom Graph - AFR results about 12.7 is the red line - below it is rich above it is weak - acceptable would be 11.5 to 13.5.
Blue Line - No Controller
Red Line - Final Positions on Controller
Green - Intermediate run - more Torque - Less HP
Finally we did a through gear run.
Now some comments from Roy interpreting test.
1. Controller is not that good / adjustable - but results are OK - and ratios are OK - not the best.
2. CAM is tuned for high RPM
3. AFR around the 2000 to 4000 RPM can not be corrected with controller
4. Standard Injector - did not give enough fuel for kit - even with controller (although Snakes did) - so maybe controllers dont behave same??
5. Its still pretty good power from a 2V 125
6. The bike is geared too tall for the power - he advised reducing 1 or 2 teeth on front - this being evident from the last graph - where you can see it can not make peak power in 4th due to gearing.
Roy at REPS motorycles was great - and we spent aroun 1.5 hours playing - cost was £80 - $120 ish
Final Settings on Controller
8. Std Gearing
