1 - 6 of 6 Posts
Does anyone ever take a couple links out of the chain after it breaks in a little to make the wheelbase a little shorter?
Thats not a chain breaking in, that's a cheap chain wearing out. The only time to remove links is when changing sprocket sizes.
So what if your sprocket combo puts you at the next to the last hashmark with the chain adjusted properly? Just throw the chain out after it stretches a quarter of an inch? Like if you put a 14T on a brand new bike, you couldn't remove two links right away but you probably could after a running a few tanks of gas through it.
As mnnthbx stated, a quality chain wouldn't stretch that much.
Going from 15T to 14T would not require removing a link, let alone two.
You can't really remove just one link unless you have a special half link made for that purpose. I know it's not necessary to remove two links to run a 14T sprocket, I was just asking if anyone does it to get a little bit shorter wheelbase. According to gearing commander, 14 34 gearing with a 2 link shorter chain moves the sprocket distance .38" closer. There might not be enough adjustment to do it with a brand new chain and sprockets (maybe there is, I don't have new parts right now to check) but there would be after things wear in a bit.
You can inspect the chain and measure it with a chain stretch gauge. As long as it remains in spec, you shouldn't have any issues shortening it to maintain a shorter wheelbase. The problem arises when you stop measuring stretch and simply think you can keep adjusting because you have room to slide it back.
1 - 6 of 6 Posts
