1 - 3 of 3 Posts
I have 2 shifting issues both involving neutral.
1) some times when I am at a red light or stop sign i shift all the way back to first, then when i start to go, the engine revs and kicks into neutral.
2) some times the shifter gets stuck and will not go into neutral , it will only shift from 1 to second when trying to start the bike. It isn't about "finding neutral" the shifter physically wont go into it.
I'm wondering whether to take it into the shop or if it is an easy fix. I only have about 600 miles on it, bought it 2 months ago.
Neutral is physically between 1st and 2nd. So it is about finding neutral. Try it without the engine running and see if it is any easier. Also try downshifting to 1st while rolling before you come to a stop. That helps prevent it from jumping back out of gear.
How much clutch cable slack are you running? Maybe too much slack; clutch not disengaging completely.
1 - 3 of 3 Posts
