1 - 2 of 2 Posts
Does anyone know the thread size of the stator nut on the SF or the crank's threads? Have an OG 4th bearing which obviously does not work on the SF. I was going to get the machine shop at work to turn down the base but the lathe will not hold it from the nut end properly. They said if I got the thread size/pitch of the threads they could cut a threaded arbor to hold it true & turn down the base to make it work. Much cheaper than buying a Takegawa for over $100!
Any info is greatly appreciated!
Discussion Starter · #2 ·
M12 x 1.25 in case anyone else needs to know.
1 - 2 of 2 Posts
