Hi all, i'm wondering if the chain is suppose to be leaning to one side against the rear sprocket or does this means that my chain adjustment is off?
I have 14T front, stock rear.
The chain when looking at the bottom photo does seems to be slightly curving towards right as it gets closer to front sprocket. Chain tensioner indicator for both side seems to be at the same spot.
It's a fairly new RKM chain which I have rode for about 120miles. I have adjusted twice since then. Chain slack when measured at the top of the swingarm about 35-40mm.
Thank You.
Pete
Thank You.
Pete
