1 - 12 of 12 Posts
We're my fairing mounts supposed to come w a grommet at the fairing end?
The didn't, just metal to plastic contact
Also were there additional screws to mount to the frame? My bike didn't come w those bolts
*re-uses to oem grommets
Not sure on the bolts but are they the same bolts that you remove your air box? Look similar.
Discussion Starter #6
re-use the stock grommets and hardware.
not sure what the thread is on the stock bolt off the top of my head, i can check in the AM. guessing maybe 6mm x 1??
Ok, I'm coming of a chimera intake so I've already taken those bolts and grommets off, gotta dig then up
ok, this is a decent setup, they hold the fairing nicely and look great.
instructions might have been nice, informing buyers they'll need OE grommets and bolt.
they are easy enough to install, but the 1st time is the hardest becuase you need to align the fairings up and then tighten the bolts against the frame.
also bolts should be included in the kit to mount the sensor. i have zip ties holding my sensor in place right now.
1 - 12 of 12 Posts
