1 - 7 of 7 Posts
Dumb move the other day, was tired and hooked up my battery backwards for a split second. Bike was never powered on.
Now my OTB halo running lights are dead and my aftermarket LED 7” spotlight as well. The flasher LEDs on the OTB still work but maybe they bypass the converters?
Had some wiring issues and need to look more into what’s going on but curious if this is a done deal where I have created a lot of work for myself. Any hope it’s just a wiring issue?
Discussion Starter #2
No fuses blown. This aux power I was using now has no voltage. Ironically bike is running like a charm on a new battery.
Where were you getting the aux power from?
Forgot I added on of these 4 Yeats ago. Must be dead.
OTB running lights ok tested with DC. Headlight is dead and plate running light so hopefully new rectifier will fix.
All other electronics run fun fed including the PCV Fed from 10A fuse.
1 - 7 of 7 Posts
