1 - 12 of 12 Posts
So I've noticed on watching videos that people odometers don't have a redline?
Mine reads a readline starting 8,000 rpm to 10,000?
I don't know why?
I installed a k & n filter to the TB and reset the ECU( if I did it right). It's kinda strange I go to accelerate and the rpms rev up but my bike doesn't go any faster? Sorry I'm a noob at these things.
Any ideas? Kinda need of help?
I'll try and post pics/video soon to show
Ecu need to read intake temp sensor.. should not be left out.. make sure kn filter is not rubbing throttle linkage ( hose clamp) you need to double check your work and puzzle it. May left out not been plug in.
Thanks! Yea, the sensor is still plugged into the airbox. ( would that make a difference?) should pluginto the filter? Why would my odometer have red line?
Discussion Starter #6
Not sure I under stand this, unless your clutch is slipping.
Can you explain a little more what the problem is
Dog
You nailed it! Clutch was smoked. No free play. Was on super tight. Adjusted both ends. Now we're back in business. Thanks for the replays appreciate all you input.
Also will be putting the temp sensor into the filter. Should I rest ECU again when I do that?
1 - 12 of 12 Posts
