I have a full set of Pit Bull stands for maintenance as well as long term storage through the winter. I keep my bikes on front and rear stands to prevent flat spots on the tires, a recommendation I got from Michelin's website.
When I first put my Grom up on the rear stand, I notice immediately the the Grom was sliding backward on the stand like it was just going to fall off the back. My fix was to build a 2X4 "T" which works both with the rear only and with the front as well.
For use as a rear only, the block up front prevents the slide rearward when the front tire bumps into the block/chock.
When you lift the front as well, the block no longer prevents the slide, but the top of the "T" makes contact with the wheels on the front Pitbull preventing the same rearward slide.
Thought I would pass this info along for others to use whether they use Pitbull or other brands. I imagine this issue is not just with Pitbull stands. The last thing I want is to go to the garage and find my Grom on the floor beside the stands.
If you added rear spools such as the Yoshimura, you will not need the brace.
