1 - 20 of 34 Posts
not enough room in the stock arm to fit races and decent bearings, thats why. same reason i didn't. bushings are very, very strong. especially on this lightweight turd of a bike, they'll probably last forever.
For a hundy sixty you can have real bearings AND an aluminum swinger. FYI...
Reactions: ikeus685
Installed them without issues thanks to video install and installing tools provided...thought oem bushings were going to be harder to take out...
Didnt make a final picture of proper install (only have a picture of them installed with the oem washers, wich dont have to be mounted with the kit installed. But i made the picture to show it to greg at mnnthbx)
Still have to test drive them, but swing arm now actually swings!!!!
I was able to take mine for a good ride yesterday and what a difference... it actually feels like I have working suspension on the back of the bike now!
what are you guys feeling? more solid feeling or?
So basically, the rubber bushings don't really do much of anything but cause binding in the full motion of the swingarm taking away quite a bit from the rear shock. With the bronze bushings the swingarm moves through it's full range of motion and actually allows the shock to do it's job. For the first time, I actually have static sag on my bike!
Just received and installed the bushings today. Super fast shipping from MNNTHBX, thanks guys.
Heads up to those with Driven rear sets. You remove the outer swing arm washers during the rear set install and these bushings push your rear sets outward back to a stock position, leaving about a 3mm gap in the bottom bolt space. I ending up just shoving 3 x 8mm crush washers into each side for the time being.
I haven't ridden it yet, but the swing arm moves free and I now have to reset my sag in the rear RB adjustable shock. You can definitely tell how restrictive the stock bushings were. Can't wait to take it for a ride.
Auto part Suspension part Suspension Vehicle Wheel
Auto part Pipe Engine
Auto part Tire Wheel Photography Suspension
Auto part Automotive exterior Bumper Pipe Vehicle
Has anyone run the swingarm bushings with the stock rear shock? For just commuting comfort and slightly better rear suspension performance, would you recommend? My concern is that the stock shock is so poorly damped that it may start to pogo if the swingarm can move more freely.
I installed my bushings last week and felt a pretty big difference. For reference I installed the Racing Bros fork kit and the Shicane HLR rear shock. I'm not a professional at suspension setup but I know how to set rider sag by adjusting the spring preload and getting the rebound set so it doesn't bounce excessively. I got obsessive about tuning my R6 suspension and I watch a lot of Dave Moss videos lol. When I got the Grom, I knew I had to get a really adjustable suspension setup or I would never be happy with it. I rode the Racing Bros setup for a bit before installing the MNNTHBX swingarm bushings, so I got a real good feel for how the suspension felt. The install was pretty straight forward using the tools and watching the YT installation video. I left the rear shock settings as I had used them on the stock bushings to see if there would be any difference in setup.
Right off the bat I noticed how stiff the suspension felt and there was barely any sag with me sitting on it. This told me how much the stock bushings were causing the swingarm to bind and not want to move at all. Previously I had about an 35mm of sag setup and I was barely getting 10mm after the bushings. After taking about 2 full turns out of the preload adjuster, I got it back to around 35mm of sag again. The rebound and compression were also way stiff. The rear suspension definitely feels livelier and more active vs. the stock swingarm bushings. After spending some time tuning the Hi/Lo speed compression I was able to get it feeling plush on the harder hits like on potholes and bumpier roads, while be very supportive while cornering hard. These bushings are a "must do" mod IMO if you want the best suspension action out of your Grom.
1 - 20 of 34 Posts
