1 - 10 of 10 Posts
Hi guys
I've just installed the TB cam and adjusted the valves, and am getting this rattling noise when idle, which gets louder with revs. I originally had the valves at 0.003 and that had the noise, and now have set to intake 0.004 and exhaust to 0.007, and it's still doing it. Any ideas? Thanks
Check the timing marks ASAP! Sounds like you may be a tooth off on the cam sprocket! Also, have to wait for the CCT to pump up with oil, may take a min or so......
2020 Honda Monkey and others
Agree with Shush. Sounds like you are off a tooth if the valves are adjusted properly.
For some reason I thought you did a throttle body install. Abbreviations!
thank you. I followed a YT video that suggested zip tieing the chain to the cam sprocket. After I refitted the sprocket bolt i lost TDC but went back round to get it.
Once done i took it round the block and it was still making that noise. I'll let it cool down overnight and open her up again tomorrow.
sorry for the dumb question, but when you say "a tooth off" what do you mean? I followed this video
Definitely want to recheck valve clearances and everything again. Timing marks do look slightly off to me.
The dash by the T should be in the middle of the inspection hole and then the sprocket dot and cam hole notch lined up.
This with cam chain tensioner installed.
1 - 10 of 10 Posts
