Hi, I just recently purchased a new Grom, and currently have done the following modifications (performance wise):
aRacer Mini X ECU
aRacer AF2 module with Bosch 4.9LSU wideband sensor
Toro full exhaust system
Unknown intake (K&N filter, potentially chimera? Last owner did the mod)
The reason I have the aRacer setup and not just an ECU flash is because I planned on modifying the engine further after purchasing it. That time has now come.
I want to install a TB camshaft and a DHM high compression piston for more power in the top end.
My questions are:
1) At what RPM does the TB cam with DHM HC piston stop making power at?
2) Should I also upgrade my injector to a PCX150 if I do the TB cam + DHM HC piston? Keep in mind I also have intake and exhaust without baffle, so will this upgrade max out my injector?
3) If I want to raise my rev limit to have longer time in the powerband (as in above 7k when the cam really starts to kick in), how high can I go safely with stock valves, springs and retainers?
4) If I upgraded to the DHM titanium valve retainers and high rpm valve springs, how high could I safely rev the engine to without having to worry about breaking other components? Would getting a new cam chain tensioner allow me to safely rev slightly higher than without an upgraded cam chain tensioner? If not, what would?
5) In addition to the TB cam and DHM HC piston (and maybe valve springs + retainers), do you think it is worth getting my head ported or getting a larger valve head also?
6) Once I have done the TB cam + DHM HC piston upgrade, is it worth getting a small oil cooler, as I will be making a 2.5 hour journey in a few months and will be sat at 50-60mph for most of it, which is very high in the rev range so will probably get very hot
Sorry for lots of questions, just currently trying to work out the best options for power and reliability at stock bore (I will NOT go big bore so don't even suggest it).
Thanks guys
EDIT: Forgot to add the 6th question
aRacer Mini X ECU
My questions are:
Thanks guys
