1 - 4 of 4 Posts
MNNTHBX Exhaust, Chimera Intake, Bazzaz ZFi, and 14t sprocket up front. I put the MNNTHBX map provided by them (is it okay for me to provide a copy of that here?).
I'm 6'2" 225lb. It feels a little faster on the top end, but not great, and I got about 7mph additional top speed, so I'm topping out at about 63mph, and before that I hit 56 with just the 14t and none of the bolt-ons. Does this sound normal?
I'm also throwing a code, but only if I am WOT for several miles and down shifting hard. If I turn the bike off and on again the code is cleared for several more miles, so it is difficult to see exactly what code I am throwing. Any recommendations there?
It also sounds like it might be popping a bit on the top end when I let off the throttle, is that normal? Apparently it could mean it's running rich.
While I was installing the Bazzaz I attempted to start it but didn't have the Bazzaz plugged in completely so the motor just turned over without firing up. Could this have caused any problems?
Questions about MNNTHBX exhaust, Chimera, and Bazzaz power output, and throwi...
Now someone may have a better option then this because I'm not an expert with trouble shooting the Grom. It won't hurt anything. Anyways what I would do first is make sure everything is plugged up right. (Check the ECU and intake connector)After that I would erase all codes and reset the ECU. After that I would go riding again trying to replicate what you were doing before to see if the CEL will come on. After that I would try and see if you can read the code immediately after it comes on.
http://www.inveniamperformance.com/installation--info.html
This site will point you in the right direction as far as ECU related things like reading and erasing codes and resetting.
Installation & Info - Inveniam Performance
I think i will have to clamp a gopro pointed at the gauges to get that code. Might work. I'll try that. Thanks for the link.
1 - 4 of 4 Posts
