1 - 2 of 2 Posts
just wondering whats the best way to cycle oil through motor before first start up, do i uninstall the spark plug and then start it up? or do i keep the spark plug installed but unplugged and then start it up? which way is the proper way because i am unsure. at the last steps of my dhm kit install
If you've already used lube during assembly, just send it.
*Lower your fuel base first if you haven't already. Didn't realize this and ran the engine rich and fouled the spark plugs. I should probably check the O2 sensor too.
1 - 2 of 2 Posts
